96 Cummings idling problem
Old Apr 29, 2009 | 05:29 PM
dmarlow508's Avatar
dmarlow508
Question 96 Cummings idling problem
When idling in nuetral, everythings fine, however when stopped at redlight, idle is up and down. Also when backing up, and I brake fast, engine will die. Any suggestions, only 76,000 miles.
Old Apr 30, 2009 | 01:03 AM
rabbler's Avatar
rabbler
Maybe you just need to adjust the Idle speed.
What RPM does it read in gear?
BTW its a Cummins not Cummings engine
Old May 7, 2009 | 11:25 AM
dmarlow508's Avatar
dmarlow508
Default Idle
Park and Neutral it idles at about 800rpm, but in drive it flucuates between 400 - 800 rpm. Something is pulling down the engine.
Old May 7, 2009 | 09:22 PM
Cartalk2's Avatar
Cartalk2
Is Air on -- try with AC off????
Old May 12, 2009 | 02:26 PM
12valveman's Avatar
12valveman
nothing should be pulling down the motor the ctd should be able to handle that ac dont you think..... have the idle speed set up govenor in pump is not reacting fast enough is usually what i have seen due to low idle
Old May 12, 2009 | 07:34 PM
Cartalk2's Avatar
Cartalk2
I could be wrong, but I think the idle should be set with trans engaged, not neutral.
I on pupose reduced my idle speed to 500/550 and it is steady.
Old May 12, 2009 | 08:59 PM
racer9's Avatar
racer9
Idle speed adjustment procedure and specs; http://www.dodgeram.org/tech/dsl/adj...d_Gen-Idle.htm
