05 cummins spins over but will not start
Old 05-12-2009, 08:41 PM
deer head's Avatar
deer head
deer head is offline
Default 05 cummins spins over but will not start
05 cummins spins over good but will not start. you can pull sart it and it will start right up are you can hit it with sterting fluid and run fine? I checked the lift pump and it is fine all the fuse are fine?
Old 05-13-2009, 10:23 AM
12valveman's Avatar
12valveman
12valveman is offline
someone needs to check it with a scanner and see if the fuel system is building enough pressure to allow start... injectors leaking by or a scored pump could cause this... even jumper tubes to the injectors leaking just a small bit of fuel could do this .... tougher to build the fuel pressure under slower crank than when you are pulling and creating more rpms to build that head pressure to the injectors.. could start by retorquing the injector jumper tubes..37 foot lbs but the lines need to be removed to do this have seen a few corrected by this otherwise your probably lookn at inj or something like that,,,,,,warranty yet?
Old 05-13-2009, 11:47 PM
twiessmer's Avatar
twiessmer
twiessmer is offline
just went through this with my 05 a year ago... 6 cracked injectors. lucky i was still under warty. do you have lots of black smoke ?
Old 05-17-2009, 10:13 AM
mopar1973man's Avatar
mopar1973man
mopar1973man is offline
Even though the Cr engines are electronic injectors it still needs to get the rail pressure up to POP the injector properly and get a good spray pattern.
Check you lift pump for good fuel pressure (greater thar 9.5 PSI)
Check your fuel filter.
The last time I seen this was on a 2004 Dodge cummins and the guy ended up taking it to the dealer to test it. Needless to say the Dealer said all injectors were leaking and not allowing it to start properly.
Old 05-19-2009, 10:44 PM
cummins67L's Avatar
cummins67L
cummins67L is offline
The Dealer said all inj so they did not have to find the bad one.
Old 05-19-2009, 10:47 PM
cummins67L's Avatar
cummins67L
where do you live? check codes,
Quick Reply: 05 cummins spins over but will not start
