sluggish 01 ctd... need help!!
Old Aug 9, 2009 | 10:09 AM
tski's Avatar
tski
Exclamation sluggish 01 ctd... need help!!
i have an 01 ctd that feels sluggish. i have the juice with attitude and when its on level 5 is the only time it has any gumption. my egt's are in the hi 700's to low 800's driving down the interstate. the monitor reads 0 boost psi but it sounds like its working just fine. there is a little smoke on start up and nothin after. fuel pressure is 14 at idle and 11 at a wot. anything i can check or do? thinking of an 05 turbo upgrade....
Old Aug 9, 2009 | 10:30 AM
racer9's Avatar
racer9
Start with the basics, before throwing parts at it.
How's the air/fuel filters?
Auto trans? Might be slipping?
Does it coast OK, or seem to drag down?
Just start doing it, or always?
Check the codes, might be a sensor.
Old Aug 9, 2009 | 12:32 PM
tski's Avatar
tski
air & fuel filters are new. coasts fine its been that way since i bought it about a year ago. it needed a lift pump and injection pump. the only code i have i a cruise contol over voltage and abs sensor open code. trans shifts good and did a tranny oil change about 5k mi ago. no shavings or clutch material
Old Aug 30, 2009 | 08:44 AM
tski's Avatar
tski
how about a valve & timing adjustment. i dont know if its ever been done and its got 240K mi ????
Old Aug 30, 2009 | 09:23 PM
racer9's Avatar
racer9
No timing adjustment, it's all electronic (that's one of the things tuners do).
If valves have never been done, that's a real good place to start.
