Sluggishness fixed!!!!
Old Sep 9, 2009 | 07:28 PM
tski's Avatar
tski
Default Sluggishness fixed!!!!
ahwile ago i put out a thread on my 01 5.9 being very sluggish since i bought it. i had the valves check and the mech told me the were fine but the plastic on the boost sensor was loose. i put in a new one and wow what a dad gum difference. 0-60 time 9.3 up from 17. and 1/4 time 12.4 from 20.0. thanks for the help in the right direction yall.
Old Sep 10, 2009 | 07:38 AM
tski's Avatar
tski
also how much boost is too much and how high is too high for egts?
Old Sep 10, 2009 | 02:33 PM
srountreeoo7's Avatar
srountreeoo7
I don't know about boost, But anything higher than 1350 egt's is getting time to back off the skinny peddle in my opinnon.
Old Sep 11, 2009 | 07:41 PM
dodgetrucker75's Avatar
dodgetrucker75
as far as boost goes... if you are getting close to 50psi you will be changing a head gasket real soon, but anything under 45psi, the HG should be fine, and if you are on a stock turbo, dont go over about 35psi, beacuse your turbo gets out of its map range and will build an enomous ammount of heat. and try to keep egt;s down under 1,300 if your probe is in the exhaust manifold, but if it is after the turbo, in the exhaust pipe, i wouldnt go over about 1,000
Old Sep 11, 2009 | 09:29 PM
3500reddragon's Avatar
3500reddragon
tski,
Could you please post your symptoms again or let me know the title of your previous thread? I am having the same problem and want to compare my symptoms to yours, etc. You can see my own thread on the subject in this Cummins section.
Thanks!
Old Sep 12, 2009 | 12:35 AM
tski's Avatar
tski
hey dragon:
my last thread was sluggish 01 ctd... need help. its on page 4 in this fourm. my symptoms were low power, no smoke except for start up, poor fuel milage. it really didn't have much tourque either. it took forever to get up to speed and anything above 60mph it didnt maintain speed very well unless my juice w/ attitude was turned up to like level 3 or 4. runnin down the interstate i had to keep it on level 5 to maintain speed. the sensor runs about 220 bucks. i had to go through a dealership and they told me the manufactuer had changed so you will need a pigtail for the new sensor to plug into the exsisting loom. it runs about 50 bucks i think.
Old Sep 12, 2009 | 09:15 AM
3500reddragon
Thanks for the info, tski. I don't have many HP mods as my vehicle is used for work hauling, etc, but my symptoms are amazingly similar to what you wrote. Was the sensor so loose that you were losing boost pressure? I assume your sensor is also located in your intake manifold (I've got a 1998.5 24v). On my truck you can hear the turbo trying to spool up, but it just doesn't get there. I figure there has to be a leak somewhere or the wastegate or actuator is malfunctioning.
Old Sep 12, 2009 | 04:53 PM
tski's Avatar
tski
the plastic where the wires plug in was loose where it meets the brass part of the sensor. i took it apart and the circutry was burnt like it got moisture in it. i thought mine might be a wastegate too but it was more expensive than the sensor. it only took me a few minutes to replace too. i took the mount where the fuel filter is off and its easy to get too. it should be right behind it.
Old Sep 12, 2009 | 05:03 PM
3500reddragon
Great! Thanks tski!
That is going to be the first thing I check when I get back to my yard. Thought I'd be able to go there today, but it's a no go. Too many things to do for my 4 YO daughter's B-day. That definitely takes priority!
Old Sep 13, 2009 | 08:16 PM
tski's Avatar
tski
you too? we just got done with my 4 yr olds party too. sefinatly a priority
