Ram diesel Engine/Cabin heater
Old Oct 3, 2009 | 03:54 PM
lesimon's Avatar
lesimon
Default Ram diesel Engine/Cabin heater
I was hoping that someone has installed and used the mopar engine/cabin heater and might be able to give me feedback on how it worked for $1400. I am looking at -40 to -50 below weather and I am trying to get my truck ready for it. I will be purchasing electric battery blankets cold front end cover to start as well as lots of fuel antigelling power service white bottles. I would appreciate any feedback on how to prepare my truck for the cold weather.
Old Oct 19, 2009 | 03:34 AM
buckskin's Avatar
buckskin
Does your truck have a block heater. I live where temps get well below zero as low as -40 or less sometimes. I park my truck inside, plug in the block heater, use power service and a radiator cover. I have had no problems with starting, gelling or low engine temps. Save your 1400.00.
Old Oct 19, 2009 | 09:00 PM
hay is for horses's Avatar
hay is for horses
Default cold weather
there was acold weather reflash for these trucks. I forget the TSB # that covered it. Anyways it was basically increase the idle rpm a few seconds after the engine stated to help with engine warm up apperantly there were issues with normal idle not wrming up the engine then only running the engine a short time then shutting it down and the valve pushrods sticking and bending from carbon and what not. I live in the cold weather area as well only I use the windshield scraper to wege on pedal and seat to adjust the rpm . Cheaper and just as effective.
Old Oct 20, 2009 | 03:51 AM
cardude's Avatar
cardude
i have this installed, did the install myself, okay when you have a lift, here in denmark europe and somtimes on my ski-vacations, i have had the truck (2500hd 2005 , 5.9) in around -4 degrees farenheit, and the cabin heater worked fine, a little smal though for the engine, it takes around 1 hour to heat up the engine and cabin (engine around 160-170 farehenheit) but it works,
and it only works on more than a half tank of fuel, when the tank is les than half full it cant suc the fuel to the heater.
works very well actually, radiator blanket shortens the heating time a little bit
