Transmission ??
Just service my transmission, when making a turn it feels like the transmission slips. I let the temp get up, recheck the level and its full. Any have or had this happen to you? Any other advice on what else to check for? I have 38000 on the clock.
Thx
Thx
well make sure you are checking in neutral! big thing probably are but ya never know might have a brain fart i do from time to time no bands to adj on a 07 shoud have the RFE trans so no adj did u leave any seals off filter or leave two in there anything wierd other than that there is nuttn u can do to screw things up too much
There is an TSB 21-09-07 to replace the governor solenoid. 2500 diesel should have a 48RE transmission. The front band could be too tight and causing the transmission to feel like its slipping. Was the trans slipping before the service?
Be prepared!!! I just picked me 05 3500 up from the trans shop, (rebuilt) $$$$3,500. At least he gave me some K-Y with my bill!!! Mine was slipping and shifting funny. I dropped my pan and found broken snap ring!!!
