Digital Monitors / Gauges
Old Oct 30, 2009 | 10:41 PM
Grr287's Avatar
Grr287
Default Digital Monitors / Gauges
I don't have any performance upgrades, except for the Edge Mileage Max. But i still want to be able to monitor my EGT, boost, and trans. temp. I don't want the hassle of 3 different gauges in pods. i don't plan on adding any performance upgrades except for an air intake. would a monitor work well for me? does anyone have any suggestions?
Old Oct 30, 2009 | 11:11 PM
pizzo's Avatar
pizzo
monitor I am getting gauges myself. the three gauges will give you trouble you loose that handle on the drivers side. Since I use the handle. I am having a three pod made out of another post with handle i bought. its costing me a pretty penny BUT I think it will be worth it. since your looking stuff www.doghousediesel.com he has the BEST prices dude. I am serious I have looked around and for the money that you spend its just better to buy from him. Just tell him Pizzo sent you from DF. Also if you get that stuff from him and since you live close if you need a hand installing it I will drive down on a saturday and help out anyway possible.
Also buy the time I am done I could have bought programmer but I already have one that don't monitor anything
Old Oct 31, 2009 | 07:55 AM
Coal Train's Avatar
Coal Train
If you just want a stand alone monitor, here's what I'd recommend.
http://www.edgeproducts.com/product....pvname=Insight
It has all the same features and monitors as the Attitude does when combined with the Edge Juice, but this is a stand alone monitor.
If you want it mounted on the pillar and want to keep your grab handle, here's the mount you want. It's the one on the far left in the picture and it simply goes over your existing a-pillar.
http://www.edgeproducts.com/product....e+Pillar+Mount
Here's another option.....
http://www.quadzillapower.com/produc...ex.cfm/p/Scout
Nice thing about the Quadzilla Scout is that you monitor fuel pressure with the add-on kit.
Or, you can use this too.....
http://www.bullydog.com/product/inde...uct_detail/290
The only thing that isn't read through the OBDII port is the EGT's. That's the only conenction that you need to drill and tap for.
Old Nov 1, 2009 | 01:20 AM
Grr287's Avatar
Grr287
sweet, yea i was looking at the Edge insight earlier. Does the EGT thermocouple install into the monitor, or is there more to it?
Old Nov 1, 2009 | 08:59 AM
Coal Train's Avatar
Coal Train
Plugs right into the port on the monitor.
It's got it's own connector, so you can't just use a standard K-type thermocouple.
Old Nov 28, 2009 | 05:39 PM
2005RAM2500's Avatar
2005RAM2500
Can the trans temp be monitored thru the OBDII port, I have 2005 2500 auto.
Old Dec 3, 2009 | 10:19 AM
georgeshannon's Avatar
georgeshannon
I have the same question. Does anyone know if the transmission temperature is available at the OBDII port?
Old Dec 3, 2009 | 11:00 AM
Coal Train's Avatar
Coal Train
Yes, the tranny temp is available via the OBDII port.....
Not with a standard tranny temp gauge, but the Insight, Scout, Outlook, etc., all monitor tranny temp through the OBDII.
Old Dec 3, 2009 | 12:24 PM
georgeshannon
Thanks for the info. That's what I needed to know. The standard tranny temp gauge must use a thermocouple installed in the tranny line somewhere.
Since we're on the subject of gauges, is there a way to get accurate EGT without tapping into the exhaust manifold? An easier alternative?
Old Dec 3, 2009 | 01:03 PM
Coal Train's Avatar
Coal Train
Nope, gotta tap.
Drilling and tapping is easy and isn't as involved as folks make it out to be.
It's just a matter of pre or post turbo.
Pre-turbo is the best spot for performance and actual monitoring. Post-turbo is best for monitoring exhaust brakes and cool down timers.
