Help!!!
Old Nov 29, 2009 | 01:13 AM
cowboy128's Avatar
cowboy128
Question Help!!!
I am in the middle of changing the water pump on my 07 5.9L ram got the bolts out but it just won't let go. Is there an easy way to get it free or does it just need to be forced off?
Old Nov 29, 2009 | 04:05 PM
NickBeek's Avatar
NickBeek
Welcome to the forum. I haven't done one yet, but I imagine a little prying may be in order. I just looked at the service manual. It doesn't give much info other then remove bolts and remove water pump. It looks like there is an o-ring sealing the pump to the block, that may have expanded and be what is holding you up.
Old Nov 29, 2009 | 04:28 PM
Mean Green's Avatar
Mean Green
If you are postive all of the bolts are off then go at it with a pry bar. I personally always start small and work my way up so I don't damage anything so try that route.
Old Nov 29, 2009 | 11:07 PM
cowboy128's Avatar
cowboy128
I always start small and work my way up to a bigger bar too. I'm thinkin its just the o ring that's stuck. Just wanted a second opinion before I went back at it
thanks for the info
Old Nov 30, 2009 | 05:43 PM
NickBeek's Avatar
NickBeek
Let us know how it goes.....
Old Nov 30, 2009 | 06:13 PM
ET RAM's Avatar
ET RAM
If it is not off yet, tap it with a mallet or rubber hammer. The seal tends to hold it in place.
Old Dec 3, 2009 | 10:46 AM
cowboy128's Avatar
cowboy128
well I got the water pump changed yesterday. apparently sitting with the bolts out for a couple days was all it needed, it had fallen out on its own.
The belt however is proving to be a much bigger pain, the winter weather isn't helping things either
Old Dec 5, 2009 | 07:33 PM
NickBeek's Avatar
NickBeek
I have not had to change mine yet, so I'm guessing at this. Can it be slipped between the top of the fan shroud and the fan?
