CP3 Pump leaking??
Old Dec 22, 2009 | 07:39 PM
ecwrestoration@yahoo.com's Avatar
Default CP3 Pump leaking??
05 ram cummins, just replaced my fca with a new one ran good till i went to the store, got out and noticed diesel leaking bad out of the engine compartment. Go home and opened the hood and saw and opening(1") hole just to the side of the fca? Is there a plug that blew out? Anyway the truck will sit for now, I guess i need a new cp3 pump? Anybody know what was in that hole? Can a new plug be installed??
Last edited by ecwrestoration@yahoo.com; Dec 22, 2009 at 07:52 PM. Reason: new question
Old Dec 22, 2009 | 08:40 PM
Coal Train's Avatar
Coal Train
I hate to tell ya, but the pump is destroyed.
Let me guess, this is what you're looking at?.....
I bet if you go under the truck and look up, the bottom plug is gone too.
When one of those plugs blows, it's shot. No if, ands or butts.....
Just replaced one for a customer about 2 months back for the same thing.
Let me know if you need help getting the pump.
Here's what his looked like before I replaced it.....
And here's what the new one looks like.....
Old Dec 22, 2009 | 09:24 PM
Thats the puppy! the truck still runs good with the plug out??? just ran to get a 1" plug you don't think i could replace it??How much for a pump?
Old Dec 22, 2009 | 09:30 PM
pizzo's Avatar
pizzo
From dodge 2200 you had better get it from Coaltrain It will be cheaper
Old Dec 23, 2009 | 03:14 AM
Coal Train's Avatar
Coal Train
NO!
DO NOT RUN THE TRUCK LIKE THAT.
What you did is blow high pressure fuel into the low pressure side. The low pressure side of the pump is all the fuel used to lubricate and cool the pump.
With that plug blown, there isn't sufficient fuel pressure to lubricate the pump.
You can try putting the plug back in, but within a few miles it's gonna blow right back out.
What will happen is the pump will seize and, remember that it's driven by the timing gears, you end up with much larger carnage.
DO NOT DRIVE THE TRUCK LIKE THAT.
Old Dec 23, 2009 | 03:36 AM
Coal Train's Avatar
Coal Train
I sent you a PM on the pump.
Old Dec 23, 2009 | 11:50 AM
Thanks for the price coal train, took and hour to get the pump out, have to see what funds are available for replacing the pump. For now the truck will sit, Hope for no snow!! Won't be able to plow!! could'nt figure out how to remove the fan, ended up removing fan, pully & engine bracket ***.?
Old Dec 23, 2009 | 01:49 PM
Coal Train's Avatar
Coal Train
Man, you didn't have to remove all that stuff.
The only thing that needs to come out is the fan shroud and the belt, unless it was an 03 - 04 truck and had the kickdown bracket over it.
Here, this is all it takes to get the pump out and the new one in. Just follow the link and go to the 3rd one from the bottom.
http://www.doghousediesel.com/id13.html
Old Dec 23, 2009 | 08:34 PM
Thanks for that tip now! Was following another install instructions from someone else, your way was alot faster. Was so pissed off, started ripping what ever to get it out!
Old Dec 23, 2009 | 08:38 PM
Coal Train's Avatar
Coal Train
If you have something like that, just give me a holler and I'll get you strait.
No sense in re-inventing the wheel when someone's already done the work for ya.
