AC problem
Old May 15, 2010 | 10:25 PM
dawgfan's Avatar
dawgfan
thanks for the tip, i'll check it out. Is there anyway to reach in there and push on the door to open it up?
Old May 16, 2010 | 09:49 AM
Roge_H's Avatar
Roge_H
Could this be the same problem if the air starts blowing hot air from both sides? This will be the 6th time I have had to take my 06 in for air problems. The entire system was changed out last summer. Now it has stopped blowing cold air again.
Old May 17, 2010 | 08:51 PM
pizzo's Avatar
pizzo
You may have that problem again but you A/c unit maybe broken, lost freon someplace most likely if you had it done the seal for the A/c condensor or evaperator is bad. or the compressor is leaking I would honestly you will need to take it back to where you had it fixed and let them deal with it... They fixed it and now its broken again that is what is in my mind.. If you came to my shop and it broke again I would be willing to work with you one the subject I am sure they would too.. they might not cover everything you may have to cover the labor or the parts and those parts are like 60 bucks from the dealer guys FYI
