The Stealth BOMB'r is under the knife
Old Aug 11, 2010 | 09:32 AM
  #111
Coal Train's Avatar
Coal Train
We pulled the pan and there was NOTHING in it, so I decided to hold off until this winter, while I have a few other things planned for it.
Swapped the filter, cleaned up the pan, drained and flushed the converter and put 'er back together.
This winter I'll pull it apart and rebuild it all.
Right now it's working perfect.
Old Aug 11, 2010 | 09:34 AM
  #112
brettj2408's Avatar
brettj2408
good to hear. im looking forward to see what in your trans
Old Aug 11, 2010 | 10:55 AM
  #113
Coal Train's Avatar
Coal Train
The most difficult thing about that trans is the valve body.
Otherwise, it's really not that bad.
Old Aug 11, 2010 | 11:06 AM
  #114
brettj2408's Avatar
brettj2408
yours a fully built suncoast?
ive rebuilt 48RE and 68RFE before but never seen inside a fully built up trans thats why im curious
Old Aug 14, 2010 | 10:28 PM
  #115
Coal Train's Avatar
Coal Train
So here's what the cab looks like now.....more like a damn cockpit.
This is why I did the oil pressure gauge. Tells ya a little different story than that dummy gauge on the dash.
PSI at idle.....
PSI at 1000 RPM.....
PSI at 1500 RPM.....
Old Aug 15, 2010 | 08:06 PM
  #116
Coal Train's Avatar
Coal Train
EBC GreenStuff 7000's and USR rotors went on today.
So far I'm impressed. After I got done bedding them in, they are certainly stronger than the stock brakes.....stronger than the tires, that's for sure.
I'll put the Ultimax rear pads on and turn the rotors later this week.
Here's the USR Rotors and GreenStuff pads.....
This is before taking it out to bed them in.....
This is after bedding them in.....
Old Aug 16, 2010 | 01:28 AM
  #117
dodgetrucker75's Avatar
dodgetrucker75
what are you running for drive & primary turbo pressures with that set up? and how are the EGT's now?
Old Aug 16, 2010 | 04:51 AM
  #118
Coal Train's Avatar
Coal Train
I don't have drive pressure and seperate boost pressure gauges on it. It's only a single wastegate and that's on the secondary, so there's not much I could do there anyways.
As for the EGT's, what I'm seeing so far is slightly higher during normal driving. Which was to be expected with the bigger cam, but lower overall EGT's in the upper end.
Haven't gotten to do any long, sustained runs in the upper RPM's to see what it does in that range yet, just some short stabs so far. Need to get about 250 more miles on it and adjust the valves and check the studs one more time first.
Old Aug 16, 2010 | 11:49 AM
  #119
hottrodder67's Avatar
hottrodder67
how hard is it to install a oil pressure gauge? I've been thinking about doing it for a while now. Like you i know the stock gauge tells a different story.
Old Aug 16, 2010 | 01:04 PM
  #120
Coal Train's Avatar
Coal Train
Easy. There are 2 extra 1/8 NPT ports on the oil filter head.
Just remove one of the pipe plugs and the sensor goes right there.
Other than that, it gets wired like any other gauge.
