wobbling front end...
Old Sep 17, 2010 | 08:27 AM
gorsuchcaravan's Avatar
gorsuchcaravan
Default wobbling front end...
Hey folks, my dad has a 2006 2500 megacab CTD 4wd, after putting new tires on his truck back in march he began to get a slight wobble, he returned to the dealer, they rotated the tires and rebalanced, but still had wobble, they then replaced the tires with a whole new set, and it seemed a little better. He then went and got a front end alignment but no relief of the wobble. He took it to the dealer and they claim they don't feel anything but state that he may have a u-joint going and it would cost hime 600 bucks to replace it. My question is could the track bar be creating his wobble?? i haven't driven the truck and all he can say is that its a wobble...any thoughts would be great.
Old Sep 17, 2010 | 10:38 AM
steve05ram360's Avatar
steve05ram360
worn tracbar bushings will cause a wobble, I would go back to the alignment though and look to make sure the caster is set to ~5.15 or greater... this will make the front end track better and reduce the chance of a death wobble experience.
Old Sep 25, 2010 | 10:06 AM
bbeamer's Avatar
bbeamer
Check those alignment settings as previously noted and then check the track bar and steering stabilizer. Its easy to see any track bar movement from underneath with someone else moving the steering wheel back and forth.
Does the wobble happen all by itself at highway speeds or does something else cause it?
Old Sep 26, 2010 | 06:53 AM
gorsuchcaravan
it seems to happen by itself but does get worse with increased speeds..usually at about 40 and above, and since we live in PA, the roads are not the best back where i am from so its usually harder on the suspensions.
