OD push button switch (electrical need help!)
Old Oct 6, 2010 | 07:31 PM
projectdakota22's Avatar
projectdakota22
Default OD push button switch (electrical need help!)
OK, I own a 94 cummins and plan on making a torque lock up switch using another OD button switch (located above the HVAC controls), so it looks clean and factory.
Anyways I got a switch from a parts ram, and got myself kind of confused...
I got all of the wires sorted out to the two wires i need in my "button switch". One wire coming from ignition power source going into my "button switch" and then other leaving my "button switch" going to a relay.
Now my problem is in my "button switch", Im not 100 percent sure of how they work.
When I push the button switch in and hold it in I have continuity between my two wires. But when i push it in let it out I do NOT have continuity.
How do I make this work so I can push it in and let it out while still have continuity through it??
Old Oct 6, 2010 | 08:12 PM
projectdakota22
Further research got me this: my OD push button switch is a "momentary push button switch" and needs a "latching relay" in order to work. When the current is turned off, the latching relay remains in its last state.
Think I'm on the right track Ill keep digging.
Old Oct 7, 2010 | 01:08 AM
jasonw's Avatar
jasonw
Site Moderator
I will move this to the diesel section for you.
