Bad Injector-shut down motor?
I got a 06 that has been in a diesel shop since mid November. The truck died on way up to hunting camp, far from home, in a huge cloud of white smoke while running down highway. Acted like someone shut off fuel to engine and it just free-wheeled to a stop. The truck started giving problems in morning, normal idle but no power then went to rough idle and no power. I got it to clear up a few times and then run with normal power for a while. Later it wouldnt start without the help of starting fluid. Then she made it a half-hour till it quite with a huge plume of white smoke and would not run or start again. So I am thinking an injector went bad, will this also shut down the fuel delivery on the engine? The mechanic said the fuel lines were full of air and foamy fuel so he changed the FCM and put a new injection pump on with no luck on getting it to fire but he said he finally had good fuel pressure. A code showed #3 injector problem. Anybody got any insight? Boe
jeezzz, what kind of a yaho are you letting work on your truck??? 2 months, a pile of $$$ and no results, i really hope you are not paying for all that! some one that just throughs parts at something hopeing it will fix itself with out proper diagnostics, should not be a mechinc, there are much quicker, eaiser, and most of all, cheaper ways to work on things....
sorry for the rant, white smoke is one of two things, a lack of fuel, or worstcase steam, which would be coming from antifreez, tho unlikely...
chances are its a fuel issue, a bad injector could cause this issue as well as a 100 other things, if its throughing a code, pull it and get it tested, i have seen a few times where fuel with water contamination, blow the injector nozzle clear off, check all codes, and get a good fuel pressure reading...
Justin i was told that in most cases white smoke means unburned fuel?? just checking to see if that is wrong ....i do see how water would cause it ...but i was always taught black is fuel and white is lack of fuel or water?? just reading and trying to learn like everyone else..Thanks Keith
