Repeated rear axle seal failure
Old Mar 8, 2011 | 02:49 PM
wapitiwme's Avatar
wapitiwme
Default Repeated rear axle seal failure
Dodge replaces rear axle seals twice and I have replaced RR seal recently. Now the LR seal is leaking. Is this unique to my 04 2500 Diesel? Reading some of the threads, I was peeked to check the differential vent. ??? Have others had a similar issue.
Old Mar 8, 2011 | 09:47 PM
M.Wise's Avatar
M.Wise
1. Vent Bad
2. Axle bent
3. bad bearings
Old Mar 9, 2011 | 04:27 PM
wapitiwme's Avatar
wapitiwme
Not likely that both axles are bent or bearings on both sides are bad... the bearings on the one wheel I had apart were perfect. Haven't had opportunity to check the vent yet.
I appreciate your help.
Old Mar 10, 2011 | 10:52 AM
wapitiwme's Avatar
wapitiwme
I checked the differential case and I can't locate any vent! Brake line connections (banjo type fitting) and emergency brake cable and and what appears to be an electronic sensor on the top left. I have no idea what that might be. Diff. is the 11.5 inch ring gear. Where is the vent supposed to be? Can anyone help.
Old Mar 10, 2011 | 02:19 PM
M.Wise's Avatar
M.Wise
the vent should be on top of axle left of pumpkin....
http://www.*********.com/forums/showthread.php?t=281730
Old Feb 11, 2024 | 04:33 PM
Kev 09 ram's Avatar
Kev 09 ram
So I recently bought a 2009 Ram 7 inch Rough Country lift 37 inch tires the rear end went out on me so I bought a complete rear end swapped it rearing went out again what could be the issue
Old Feb 11, 2024 | 06:43 PM
What axle? What weight of truck? What is failing in the axle? How long does it take?
We need more info please.
