Dodge pros and cons?
Old Nov 14, 2011 | 04:06 PM
dieselpower65's Avatar
dieselpower65
New Member
Default Dodge pros and cons?
As of rite know i have a 05 f350 diesel and ive had all the common expensive problems there known for. Im looking into getting a 5.9L dodge diesel what are the common problems for the dodges and the pros and cons of the them? Thanks for any input!!
Old Nov 14, 2011 | 09:03 PM
horatio102's Avatar
horatio102
What year are you looking at? They've all got their own little issues.
Old Nov 14, 2011 | 10:38 PM
dieselpower65
New Member
ive looked at an 05 but im also going off of price whats the best years in the 5.9s?
Old Nov 14, 2011 | 10:39 PM
dieselpower65
New Member
And are they expensive issues or just minor issues? ive had alot of expensive issues with my ford 6.0
Old Nov 15, 2011 | 08:27 PM
brettj2408's Avatar
brettj2408
Seen minor lift pump problems, quite a few injectors on 2006 thats really it for motor only seen 1 turbo go out on an 06 in 2 years the new 6.7l VGT turbos are garbage
Old Nov 15, 2011 | 09:33 PM
horatio102's Avatar
horatio102
No, the VGT turbos are not garbage - the EGR and DPF systems are garbage and they are extremely hard on the equipment. If you live in an emissions testing area and can't remove the EGR and DPF, then I'd skip the 6.7.
Old Nov 16, 2011 | 02:44 PM
dieselpower65
New Member
well it sounds like i will be alot happier with a dodge. I appreciate all the input from everyone
Old Nov 16, 2011 | 09:05 PM
maxwell11's Avatar
maxwell11
i have a 2005 dodge, 52K miles, so far its been a good truck, plenty of power and gets good mpg.
as said above each model is a bit different,
the auto trans in a 05 model only has 4 forward gears and T/H mode, so you cannot lock out overdrive when towing. Other models i understand you can lockout OD.
In my old chevy 2500 you could place the trans in 3rd and it would not shift to O/D when towing.
Other model dodges have other shift options. So you may want to go with a newer model with the 6 speed auto, if that is what you want.
towing heavy loads in OD might not be what you want to do, but i only tow about 6K, it pulls that with no problems,
last trip i got around 15 mpg towing which is pretty good.
And had all kinds of reserve power on hills.
just a heads up.
Old Nov 17, 2011 | 03:19 PM
dieselpower65
New Member
just a heads up.
thats some good info on the trans options in the different years thank you
