girl that doesnt want to be taken advantage of...
#21
i see cars that come in all day for diagnosis pay 52.50$ for me to remove a stupid little jet chip or bully dog, yes it feeds the computer a false signal if that part malfunctions, there could be other things, sometimes i get the feeling chrysler pcms just dont like chips, best thing to do, REMOVE the bullydog and put back to original settings, then RESET THE PCM JUST LEAVE THE NEGATIVE BATTERY CABLE OFF OVERNIGHT, test drive for 100 miles, IF there is a problem with the injectors the light should come on first.....or maybe you dont have all of them bad, or maybe its not that if your pluming black smoke its because you have fuel that isnt being burnt, matbe you have a glowplug issue? try a different dealer, my dealer charges 52.50 for BASIC diagnosis work.
#22
A Cummins doesnt have glowplugs. But anyway, the chip could be malfunctioning, but it could also have damaged the injectors. The free way to rule out anything would be to remove the chip and reset everything. Then give it a shakedown and see if it still does it and have lights come on.
I am just saying go to someone that will read the codes, active or inactive. Even if a light isnt on it could still have codes listed. Go see what the computer says. If it takes 50 bucks to say for sure if its injectors or not, thats a good use of 50 bucks. If it is the injectors shop around and get a good price. Sometimes though a good price isnt good service.
I hope you get your truck fixed without getting takin to the cleaners.
#23
forgot they got gridheaters...
#24
The codes everyone talks about here, is that different than the readings that came from each of the injectors?? Is there a reason that 3 of them would read over 100? Is that an actual code? I dont understand that.
I have to ask questions because I dont have the knowledge to do any of this or anyone to help so that makes this tough. Sad thing is I have already paid for answers and I am still scared with the answers I have gotten.... Sorry but I do appreciate this!
#27
Codes we are talking about are from the engines computer. Since I don't have a diesel im not sure how they are accessed. Reading codes with a gas truck is done with the key and counting the check engine light. The procedure is as follows: turn key on so lights on dash illuminate: turn off turn on again turn off, then turn on. On my trucks my check engine light comes on with the key all times but on the third time it goes out and then starts flashing. You count the flashes in sequence, sometimes it is tricky but it works. Example : light on then out for delay, then light, shorter delay light. On the gas truck this is a 12 which tells me my trucks computer has been disconnected less than 50 key strokes ago. On the gas trucks the conclusion is a sequence of 5 lights on off delay then five lights off on again which tells me end of codes. Your readings of 100 (plus or minus) could be injector pressures but then again I could be wrong. Hope this helps you at least understand what we are talking about with engine code's comments. Also keep in mind you are watching the check engine light to do this counting.
#28
kind of but not that complicated, since they already charged you for a diagnosis, ask them if there was "any stored fault codes ex: P0300 Multiple Cilinder Misfire- whatever code it is one of two things can be going on it can be set and illuminate the CEL (check engine light). It also may be a STORED code, which would not necessarely illuminate the check engine light, but it could be waiting to cycle enough times to come on just not there yet and sometimes the only way to see that is by running a Chrysler or compribable scanner to that vehicle to get the code.
ask your diagnosis tech for it.
if there is one post it back and let me know what it is, id say this is a 90% chance there is a stored code.
http://www.dieselbombers.com/5-9-lit...-injector.html
#29
on
If you are getting black smoke, that maybe an injector timing problem. I found a TSB that you need to print and give it to the diesel tech at where you are taking the truck too. Also the tech can do an injector kill test with either the witech or the starscan, that will help to find the either the injector or the cylinder that you have a problem with. Also have you posted in the diesel section on your problem? Please let me know, this way I can either leave this post here or move it the diesel section.
SUBJECT:
Cummins Diesel Diagnostics
OVERVIEW:
This bulletin provides diagnostic procedures for the fuel injection system.
MODELS:
2003 - 2007 (DR/DH/D1/DC) Ram Truck (2500 / 3500)
NOTE: This bulletin applies to vehicles equipped with a 5.9L Cummins 24-valve
diesel engine (sales code ETH or ETC).
SYMPTOM/CONDITION:
Revised diagnostic procedures are available for the following Symptom/Conditions:
· White smoke and/or misfire after starting when the engine temperature is below 66°
C (150° F).
· Engine surges at idle
· Engine sounds
· Engine cranks for a long time or will not start.
SPECIAL TOOLS / EQUIPMENT REQUIRED:
CH6000A Scan Tool (DRBIII®)
CH7000A J1962 Cable with red DRBIII® connector
CH9401 StarSCAN® Tool
CH9404 StarSCAN® Vehicle Cable
9007 Adapter, Compression Test
9011 Adapter, Fuel Pressure Test
9012 Fitting, Fuel System Test
9013 Adapter, Fuel Pressure Test
NUMBER: 14-003-06 REV. A
GROUP: Vehicle Performance
DATE: October 27, 2006
9014 Adapter, Fuel Pressure Test
9022 Adapter, Turbo Test
DIAGNOSIS:
CAUTION: Do NOT disconnect the Electronic Fuel Control (EFC) actuator or the Fuel
Rail Pressure Sensor while the engine is running. Damage to the rail
pressure relief valve may occur.
PRE-DIAGNOSTIC TROUBLESHOOTING PROCEDURE:
1. Check TechCONNECT for any Service Bulletins related to the customer concern.
2. Verify that the ECM software is at the latest level.
3. Perform the existing “Pre-diagnostic Troubleshooting Procedures” available in
TechCONNECT under: Service Info tab > 9 - Engine > Diagnosis & Testing.
4. For the engine circuit diagram, refer to the detailed service information available in
TechCONNECT under: Service Info tab > 9 - Engine > Schematics and Diagrams.
5. For a complete wiring diagram, refer to the detailed wiring diagrams available in
TechCONNECT under: Service Info tab > Wiring > 14 - Fuel System > Fuel Injection >
(component).
NOTE: Refer to the appropriate section below (A, B, C, or D) to diagnose the
customer specific symptom / condition.
SECTION A - WHITE SMOKE AND/OR MISFIRE AFTER COLD START:
Possible Causes
Air in fuel supply
Coolant leaking into combustion chamber
Active Diagnostic Trouble Codes (DTC's)
In very cold ambient temperatures, engine block heater is malfunctioning (if equipped)
Engine Coolant Temperature sensor malfunctioning
Engine Control Module (ECM) incorrect calibration
Fuel filter restricted
Fuel grade not correct or fuel quality is poor
Fuel heater element or fuel heater temperature sensor malfunctioning
Fuel Injector malfunctioning
Fuel injector hold-downs loose
Fuel injector protrusion not correct
High pressure fuel pump malfunctioning
Intake/Exhaust valve adjustment not correct (too tight)
Intake manifold air temperature sensor malfunctioning
Intake manifold heater circuit not functioning correctly in cold weather
Internal engine damage
Restricted fuel supply side of fuel system
14-003-06 REV. A -2-
Perform the Pre-Diagnostic Troubleshooting Procedure before proceeding.
1. Preliminary checks:
a. Repair active DTC's before proceeding.
b. Ensure the customer's concern is not related to situations which may increase
normal white smoke; idle time, engine temperature, fuel source, cold ambient
temperature, high altitude.
2. DTC / Product Improvement: Check for any service bulletins related to the
customer's concern or Diagnostic Trouble Codes (DTC's) present. Follow appropriate
guidelines in the diagnostic procedures outlined in TechCONNECT. Is the vehicle
repaired?
a. Yes >> Go to Step #14.
b. No >> Go to Step #3.
3. Temperature sensors: Using the appropriate scan tool, before starting engine after
an overnight soak, verify that the Intake Air Temperature (IAT), Engine Coolant
Temperature (ECT), Inlet Air Temperature, and the Battery Temperature sensors are
showing similar and appropriate temperatures. Are the sensors showing similar and
appropriate temperatures?
a. Yes >> Go to Step #4.
b. No >> Repair the appropriate sensor or circuit as necessary. Refer to the diagnostic
procedures available in TechCONNECT under: Service Info tab > 9 - Engine >
Diagnosis & Testing. >> Go to Step #14.
4. Pressure sensors: Using the appropriate scan tool, before starting engine after an
overnight soak, verify that the Intake Manifold Pressure and Inlet Air Pressure sensors
are showing similar and appropriate pressure. Are the sensors showing similar and
appropriate pressures?
a. Yes >> Go to Step #5.
NOTE: The Inlet and Baro sensors will read in Inches of Mercury (Hg) while the
Intake and Boost sensors will read Pounds per Square Inch (PSI). The values
displayed on the scan tool will not be the same, 2 in. Hg = 1 PSI.
5. Fuel Rail Pressure sensor: Using the appropriate scan tool, before starting engine
after an overnight soak, verify that the fuel rail pressure reads 0 (+/- 500 PSI). Does
the fuel rail pressure read 0 (+/- 500 PSI)?
a. Yes >> Go to Step #6.
b. No >> Repair the fuel rail pressure sensor or circuit as necessary. Refer to the
diagnostic procedures available in TechCONNECT under: Service Info tab > 9 -
Engine > Diagnosis & Testing. >> Go to Step #14.
6. Intake Air Heater: Verify the intake air heater is operating properly. Refer to the
detailed service information available in TechCONNECT under: Service Info tab > 14 -
Fuel System > Fuel Injection > Intake Air Heater > Operation. Is the intake air heater
operating properly?
a. Yes >> Go to Step #7.
b. No >> Repair the intake air heater or intake air heater circuit as necessary. Refer to
the diagnostic procedures available in TechCONNECT under: Service Info tab > 9 -
-3- 14-003-06 REV. A
7. Start the engine: Start the engine following normal starting procedures and allow the
engine to run at idle. Determine when the white smoke disappears. If the white smoke
disappears within one minute, it is normal. If the engine is operated in cold ambient
conditions and/or at altitude, white smoke at start-up is expected.
8. Test for injector misfire: Using the appropriate scan tool, perform a “Cylinder Kill”
test. Cancel each cylinder one-at-a-time. Note any change in smoke and/or misfire.
Does a single cylinder show a difference in smoke or misfire?
a. Yes >> Go to Step #9.
b. No >> Go to Step #10.
9. Diagnose single cylinder white smoke/misfire:
a. Remove the valve cover.
b. Inspect the valve lash.
c. Remove the injector.
d. Inspect the injector seal washer and High Pressure Connector (HPC). Replace the
HPC if it is damaged.
e. Install Miller Special Tool 9007 (Compression Test Adapter) and perform a cylinder
compression test. Cylinder pressure should be 350 PSI minimum.
f. Install the injector. Refer to the detailed service information available in
TechCONNECT under: Service Info tab > 14 - Fuel System > Fuel Injection > Fuel
Injector > Installation.
g. Repeat test for injector misfire. >> Go to Step #8.
NOTE: If the same single cylinder is still the cause of the miss or white smoke,
replace that single injector and HPC.
NOTE: Perform the following test if a single cylinder was not identified by the
cylinder cutout test to be causing the white smoke.
10. Test for injector leaking fuel into the cylinder: Using Miller Special Tool, 9011,
block the high pressure fuel line at the rail, one injector at a time. Is a single injector
the cause of the white smoke and/or miss?
a. Yes >> Replace that injector and HPC. - Go to Step #14.
b. No >> Go to Step #11.
11. Test for high injector return flow: Perform the “Injector Return Flow Test”. Refer to
the detailed diagnostic information available in TechCONNECT under: Service Info tab
> 9 - Engine > Diagnosis & Testing. Do the injectors pass the “Injector Return Flow
Test”?
a. Yes >> Go to Step #13.
b. No >> Go to Step #12.
NOTE: Maximum leakage allowable for all injectors combined is 160 mL (5.4 fl. oz.):
taken when engine coolant temperature is greater than 82°C (180°F), engine
speed is equal to 1,200 RPM's, and fuel rail pressure is equal to 1400 bar
(20,305 psi.).
NOTE: It is critical that all HPC nuts are tightened to the correct torque. Refer to the
detailed tightening information available in TechCONNECT under: Service
Info tab > 14 - Fuel System > Fuel Injection > Fuel Injector > Installation.
Retest when all HPC nuts are properly torqued.
14-003-06 REV. A -4-
NOTE: Any injector contributing more than 40 mL (1.4 fl. oz.) is excessive (Example:
If total injector leakage is 200mL (6.7 fl. oz.) and blocking cylinder #1 reduces
the leakage to 160 mL (5.4 fl. oz.), cylinder #1 has excessive leakage).
NOTE: Test should be repeated to confirm measurements.
12. If the injector return from any cylinder(s) is deemed excessive:
a. Check HPC tip for damage, replace HPC if damaged. Refer to the detailed service
information available in TechCONNECT under: Service Info tab > 14 - Fuel System
> Fuel Injection > Fuel Injector > Removal/Installation. >> Go to Step #14.
b. If HPC tip is undamaged, replace the injector and HPC. Refer to the detailed service
> Fuel Injection > Fuel Injector > Removal/Installation. >> Verify that a quality fuel
filter is used. >> Go to Step #14.
13. If the engine passes the previous tests and still exhibits white smoke that clears with a
warm engine, check the following:
a. Idle Time: More than 20% is excessive.
b. Engine Temperature: Verify that the thermostat allows the engine to reach
operating temperature.
c. Fuel Source (Cetane): Check with fuel supplier or try another source.
d. Fuel Quality (lubricants/detergents): May benefit by using a fuel detergent with a
lubricity additive.
e. Winter Fuels : No. 2 diesel not blended for winter conditions.
f. Cold Ambient: Use block heater where appropriate, limit warm-up time in winter.
g. High Altitude: Effect will be worse with altitude and cold ambient temperatures.
h. Refer to Service Information: Refer to the detailed diagnostic information available
in TechCONNECT under: Service Info tab > 9 - Engine > Diagnosis & Testing >
Smoke Diagnosis Charts > Excessive White Smoke. >> Go to Step #14.
14. Repair Complete: Perform Powertrain Verification Test VER - 1 (Diesel). Refer to the
detailed service information available in TechCONNECT under: Service Info tab > 8 -
Electrical/Electronic Control Modules/Engine Control Module > Diagnosis And Testing.
SECTION B - ENGINE SURGES AT IDLE:
Possible Causes
Fuel Supply (Low Pressure) System
Fuel Injection (High Pressure) System
Fuel Return
Air Intake System
Other Vehicle Systems
Base Engine
Perform the Pre-Diagnostic Troubleshooting procedure before proceeding.
1. DTC / Product Improvement: Check for any service bulletins related to the
repaired?
a. Yes >> Go to Step #15.
b. No >> Go to Step #2.
-5- 14-003-06 REV. A
2. Verify complaint: Verify proper fuel quality, grade, and level in the fuel tank. Operate
the engine at idle speed. Using the appropriate scan tool, log the fuel pressure set
point and actual fuel pressure. A good system will have actual fuel pressure that is +/-
500 PSI from the set pressure. (Example: If the fuel pressure set point at idle is 6500
PSI, the actual fuel pressure on a good system is expected to be between 6000 - 7000
PSI). If fuel pressure variation is excessive, an audible surge will be present. If the
variation is severe, a slight engine speed variation may also be noticed. Does the
actual fuel rail pressure fluctuate more than +/- 500 PSI?
a. Yes >> Go to Step #3.
b. No >> Go to Step #8.
NOTE: A loud “knock” and black smoke that exists with an actual fuel pressure drop
may be an injector issue and should be identified using the single cylinder
cut out test.
3. Verify proper low pressure fuel supply to the injection pump: Perform the
appropriate fuel supply system flow test. NOTE: This procedure may be slightly
different depending on if the vehicle has an engine mounted transfer pump or
the in-tank transfer pump. In a good low pressure fuel system, fuel flow of 560 mL in
10 seconds or better is expected for model years 2003 and early 2004. The fuel
volume for the model years late 2004 through 2007 is 590mL in 10 seconds. Be sure
there is no air in the system. Is the low pressure fuel supply sufficient?
b. No >> Repair the low pressure fuel supply system. Refer to the detailed diagnostic
information available in TechCONNECT under: Service Info tab > 9 - Engine >
Diagnosis & Testing > Fuel Lift Pump - Diesel. >> Go to Step #15.
4. Test for high injector return flow: Refer to the detailed diagnostic information
available in TechCONNECT under: Service Info tab > 9 - Engine > Diagnosis and
Testing > Injector Return Flow Test. Do the injectors pass the “Injector Return
Flow Test”?
a. Yes >> go to Step #6.
b. No >> go to Step #5.
5. If the injector return from any cylinder(s) is deemed excessive:
> Fuel Injection > Fuel Injector > Removal/Installation. >> Go to Step #15.
filter is used. >> Go to Step #15.
6. Verify high pressure pump output volume: Remove the high pressure fuel line from
the high pressure pump outlet port to the fuel rail. Connect a suitable hose to the high
pressure outlet port of the high pressure pump and route it to a graduated container.
Disconnect the Electronic Fuel Control Actuator. Crank the engine until fuel exits the
hose. NOTE: With the discharge line routed to atmosphere, fuel will discharge at
0 PSI. Crank the engine for three 10 second intervals, pausing to allow the starter to
cool between each crank event. High pressure pump output volume must be greater
than 70 mL in 30 seconds. Is the high pressure pump output flow sufficient?
a. Yes >> go to Step #7.
b. No >> Replace the high pressure pump. Refer to the detailed service information
available in TechCONNECT under: Service Info tab > 14 - Fuel System > Fuel
Injection > Fuel Injection Pump. >> Go to Step #15.
14-003-06 REV. A -6-
7. Electronic Fuel Control Actuator (FCA): Replace the Electronic Fuel Control
Actuator. Refer to the detailed service information available in TechCONNECT under:
Service Info tab > 14 - Fuel System > Fuel Injection > Fuel Injection Pump. >> Go to
Step #15.
8. Verify High Pressure System Is Functioning Normally: Using the appropriate scan
tool watch the fuel rail pressure set point. Does the fuel rail pressure set point
fluctuate at idle?
a. Yes >> Check the vehicle for signs of parasitic load causing the ECM to adjust fuel
pressure set point.
b. b. No >> Go to Step #9.
9. Idle speed fluctuation: Using the appropriate scan tool watch idle speed. Compare
the idle speed shown on the scan tool to the reading on the tachometer. Does the idle
speed on the scan tool fluctuate more than 20 RPM while the engine is at idle?
a. Yes >> Go to Step #10.
b. No >> Investigate fuel quality. Look for evidence of fuel contamination. Investigate
for aftermarket performance devices.
10. Verify proper low pressure fuel supply to the high pressure pump: Perform the
appropriate fuel supply system flow test. NOTE: This procedure can be slightly
different depending on if the vehicle has an engine-mounted transfer pump or
10 seconds or better is expected for model year 2003 and early 2004 vehicles. In a
good low pressure fuel system, fuel flow of 590 mL in 10 seconds or better is expected
for late model year 2004 through 2007 vehicles. Be sure there is no air in the system.
Is the low pressure fuel supply volume sufficient?
a. Yes >> Go to Step #11.
b. No >> Repair the low pressure fuel supply system as necessary. Vehicles
equipped with an in tank fuel pump: Refer to the detailed diagnostic information
available in TechCONNECT under: Service Info tab > 9 - Engine > Diagnosis &
Testing > In-Tank Fuel Lift Pump Flow/Diagnostic Test Procedure . Vehicles
equipped with an engine mounted fuel transfer pump: Refer to the detailed
diagnostic information available in TechCONNECT under: Service Info tab >
Diagnostics tab, Powertrain Gas, Driveability Diesel, Fuel Lift Pump Flow And Inlet
Restriction Test >> Go to Step #15.
11. Fuel Return: Check for kinked or restricted fuel return lines. Check the fuel tank
venting. Does a fuel return system restrictions exist?
a. Yes >> Repair as necessary. Go to Step #15.
b. No >> go to Step #12.
12. Intake / Exhaust Systems: Check for inlet restriction, inspect air filter for excessive
dirt/debris. Verify air intake tubes and hoses are not kinked or restricted. Check for
charge air cooler air system leaks. Perform “INTAKE AIR SYSTEM PRESSURE TEST
- DIESEL”. Refer to the detailed service information available in TechCONNECT
under: Service Info tab > 11 - Exhaust System > Turbocharger System > Turbocharger
> Inspection. Inspect Turbocharger for excessive compressor wheel movement and
proper waste gate operation. Check for exhaust restriction. Check for kinked or
blocked exhaust pipes. Verify proper exhaust brake operation (if equipped). Were any
issues found with the Intake/Exhaust Systems?
a. Yes >> Repair as necessary - Go to Step #15.
b. No >> Go to Step #13.
13. Other Vehicle Systems: Verify proper operation of the Transmission Clutch. Verify
proper operation of the Transmission. Verify proper operation of the Vehicle brakes
(check for dragging). Verify proper operation of the Cooling fan operation cycle time.
Verify proper operation of the Engine driven accessories. Were any issues found
with the Vehicle System?
-7- 14-003-06 REV. A
b. No >> Go to Step #14.
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
C (150° F).
· Engine sounds
DIAGNOSIS:
(component).
Possible Causes
Air in fuel supply
repaired?
operating properly?
Test”?
(20,305 psi.).
lubricity additive.
Possible Causes
Fuel Return
Air Intake System
Base Engine
repaired?
cut out test.
Flow Test”?
Step #15.
fluctuate at idle?
pressure set point.
#30
on
14. Base Engine: Check for internal engine damage. Valve lash settings, engine
compression, cylinder leak down, etc. Were any issues found with the Base
Engine?
b. No >> Go to Step #15.
15. Repair Complete: Perform Powertrain Verification Test VER - 1 (Diesel). Refer to the
SECTION C - ENGINE NOISE:
When standing in front of the vehicle with engine running, several distinct noises may be
heard. These noises may vary depending on listener location, 2WD vs. 4WD, engine
temperature and miles on the vehicle.
1. Gear Train Noise Evaluation
a. Normal: Gear noises noticeable when standing in front of the engine, may vary
from engine to engine.
b. Abnormal: Gears are visually damaged or have backlash or end clearance out of
specification. The cause should be identified and corrected.
2. Fuel Pump Noise Evaluation
a. Normal: Pumping noise may vary - the fuel pump is producing between 5,000 and
20,000 psi depending on operating conditions.
b. Abnormal: A fuel pump with excessive pressure variation (+/- 500 psi from set
point) is abnormal. The cause should be identified and corrected. Refer to Engine
Surge or Engine Difficult to Start symptoms.
3. Injector Noise Evaluation
a. Normal: Combustion noise may vary at different operating conditions. Maybe more
noticeable on throttle tip-in and vary from engine to engine.
b. Abnormal: Loud knock with smoke and vibration. Cylinder cut out test or
mechanical blocking of injectors (Special Tool #9011) should be used to identify
failed injectors.
4. Valve Train Noise Evaluation
a. Normal: Valve settings are correct and no visual damage to parts.
b. Abnormal: If valve settings are out of specification, they should be reset. Also,
correct any damage to rocker levers, push rods, or cross heads.
5. Refer to the detailed diagnostic information available in TechCONNECT under:
Service Info tab > 9 - Engine > Diagnosis & Testing > Engine Diagnosis - Mechanical.
SECTION D - ENGINE WILL NOT START / HARD TO START:
Possible Causes
Battery voltage
Starting Accessories
Fuel Return
Air Intake System
Base Engine
14-003-06 REV. A -8-
repaired?
a. Yes >> Go to Step #17.
2. Verify Battery Voltage: Measure the battery voltage and load capability. Is the
battery voltage sufficient?
b. No >> Repair low battery voltage condition. Go to Step #17.
3. Verify Starting Accessories: Verify the ignition switch, vehicle theft system, starter,
intake manifold grid heater, and fuel heater are functioning properly. Are all starting
accessories functioning properly?
b. No >> Repair or replace accessories as necessary >> Go to Step #17.
4. Check the supply fuel in the vehicle: Verify fuel level in the fuel tank. Also verify fuel
quality. Remove, inspect and replace the fuel filter (if necessary). Investigate for
evidence of fuel contamination and improper fuel type. Refer to the vehicle owners
manual fuel requirements section. Is the fuel quality within specification?
b. No >> Follow fuel contamination process (drain contaminated fuel, replace
damaged components, fill with proper fuel). >> Go to Step #17.
5. Verify complaint: Using the appropriate scan tool log the fuel pressure set point and
actual fuel pressure. Verify the rail pressure versus set point, this can be done while
cranking or with the engine idling. A good system will have actual fuel pressure that is
+/- 500 PSI from the set pressure. (Example: If the fuel pressure set point at idle is
6500 PSI, the actual fuel pressure on a good system is expected to be between 6000 -
7000 PSI). Does the actual fuel rail pressure meet the set fuel pressure +/- 500
PSI?
6. Check the engine oil level: Check the engine oil level. Is the engine oil level over
filled?
7. Remove the engine valve cover: Inspect for injectors leaking fuel into the valve train
area while cranking the engine. If the engine will start and idle, actuate the Fuel
Pressure Override Test on the appropriate scan tool NOTE: This feature is not
available on 2003 MY vehicles. Use the fuel manifold blocking tool, Miller special tool
#9011, to isolate suspected leaking injectors. If the leak is still present with the
suspected injector isolated, remove the injector and inspect the O-ring on the body of
the injector for cuts or damage. Inspect the injector bore for burrs or other cause for a
cut O-ring. Correct the cause of the damaged O-ring and replace the O-ring. Use
copper sealing gasket when reinstalling the injector. Refer to the detailed removal and
installation procedures available in TechCONNECT under: Service Info tab > 14 - Fuel
System > Fuel Injection > Fuel Injector. Are there any leaking injectors?
a. Yes >> Replace the leaky injector(s). Refer to the detailed removal and installation
procedures available in TechCONNECT under: Service Info tab > 14 - Fuel System
> Fuel Injection > Fuel Injector. >> Go to Step #17.
b. No >> Determine the source of fuel/coolant/other substance in the crankcase
causing the system to be over full. Repair as necessary. >> Go to Step #17.
-9- 14-003-06 REV. A
8. Check the fuel pressure limiting valve: Perform the “Checking Pressure Limiting
Valve On The Fuel Rail For Internal Leaks” test. Perform the existing diagnostic
procedure available in TechCONNECT under: Service Info tab > 9 - Engine >
Diagnosis and Testing. No leakage is expected while cranking or while at idle speed.
Does the pressure limiting valve leak internally?
a. Yes >> Replace the fuel pressure limiting valve. - Refer to the detailed service
> Fuel Delivery > Fuel Pressure Regulator. >> Go to Step #17.
9. Test for high injector return flow: Refer to the detailed diagnostic information
available in TechCONNECT under: Service Info tab > 9 - Engine, Diagnosis and
Flow Test”?
NOTE: Torque all High Pressure Connector (HPC) nuts to the correct torque and
retest. Refer to the detailed service information available in TechCONNECT
under: Service Info tab > 14 - Fuel System > Fuel Injection > Fuel Injector.
10. If the injector return from any cylinder(s) is deemed excessive:
> Fuel Injection > Fuel Injector > Removal/Installation. >> Go to Step #17.
filter is used. >> Go to Step #17.
11. Verify proper low pressure fuel supply to the high pressure pump: Perform the
for model year late 2004 through 2007 vehicles. Be sure there is no air in the system.
a. Yes >> Go to Step #12.
b. No >> Repair the low pressure fuel supply system. Vehicles equipped with an in
tank fuel pump: Refer to the detailed diagnostic information available in
In-Tank Fuel Lift Pump Flow/Diagnostic Test Procedure. Vehicles equipped with
an engine mounted fuel transfer pump: Refer to the detailed diagnostic
information available in TechCONNECT under: Service Info tab > Diagnostics tab,
Powertrain Gas, Driveability Diesel, Fuel Lift Pump Flow And Inlet Restriction Test
>> Go to Step #17.
14-003-06 REV. A -10-
12. Verify high pressure pump output volume: Remove the high pressure fuel line from
Injection > Fuel Injection Pump. >> Go to Step #17.
13. Fuel Return: Check for kinked or restricted fuel return lines. Check the fuel tank
venting. Where any problems found in the Fuel Return system?
a. Yes >> Repair as necessary. >> Go to Step #17.
14. Intake/Exhaust Systems: Check for inlet restriction, inspect air filter for excessive
charge air cooler air system leaks. Perform the “INTAKE AIR SYSTEM PRESSURE
TEST - DIESEL”. Refer to the detailed service information available in TechCONNECT
> Inspection. Inspect the Turbocharger for excessive compressor wheel movement
and proper waste gate operation. Check for exhaust restriction. Check for kinked or
15. Other Vehicle Systems: Verify proper operation of the Transmission Clutch. Verify
with the Other Vehicle Systems?
b. No >> Go to Step #16.
16. Base Engine: Check for internal engine damage. Valve lash settings, engine
Engine?
b. No >> Go to Step #17.
17. Repair Complete: Perform Powertrain Verification Test VER - 1 (Diesel). Refer to the
POLICY:
Reimbursable within the provisions of the warranty.
-11- 14-003-06 REV. A
TIME ALLOWANCE:
Usage of these labor operations must follow the guidelines outlined in the Global Warranty
Administration Manual.
NOTE: The following diagnostic labor operations can only be used in conjunction
with the main (prime) repair labor operation that corrected the condition.
Labor Operation
No:
Description Amount
14-01-10-70 Diagnostic Time for Section A - White Smoke
and/or Misfire After Cold Start.
Actual Time
14-01-10-71 Diagnostic Time for Section B - Engine Surges At
Idle.
Actual Time
14-01-10-72 Diagnostic Time for Section C - Engine Noise. Actual Time
14-01-10-73 Diagnostic Time for Section D - Engine Will Not
Start / Hard To Start
Actual Time
FAILURE CODE:
ZZ Service Action
14-003-06 REV. A -12-
Engine?
failed injectors.
Possible Causes
Battery voltage
Fuel Return
Air Intake System
Base Engine
repaired?
PSI?
filled?
Flow Test”?
>> Go to Step #17.
Engine?
POLICY:
TIME ALLOWANCE:
Labor Operation
No:
Description Amount
Actual Time
Idle.
Actual Time
Actual Time
FAILURE CODE:
ZZ Service Action
