cheap bosch injectors?
Old Mar 20, 2012 | 08:25 AM
tru35683's Avatar
tru35683
Default cheap bosch injectors?
i have to replace all six injectors (bad fuel)in my 04 cummins and found a set of remanned bosch injectors on ebay, from a high rated seller, for about $1475.00. Are they any good?
Old Mar 20, 2012 | 09:17 AM
horatio102's Avatar
horatio102
Yay for stock fuel filtration!
Call the seller and find out what the deal is. When the 6.7 came out, injectors for that were about $1500 EACH.
Old Mar 20, 2012 | 10:27 AM
tru35683's Avatar
tru35683
Here is the link
http://item.mobileweb.ebay.com/viewi...id=22460827179
Old Oct 21, 2012 | 06:33 PM
iwhitne's Avatar
iwhitne
anyone have a good price on stock injectors for a 99 24 valve?
Old Oct 21, 2012 | 07:25 PM
Jigabop's Avatar
Jigabop
why do you want stock injectors?!
you can get aftermarket performance injectors for your truck that will give you clean cool power and still work with the stock turbo.
you will want to upgrade your fuel system though which you should do even on a stock truck to protect your injection pump.
edit: just noticed you have a holley black. that should be alright. you will want a FP gauge though to be sure you are in safe levels.
Old Oct 21, 2012 | 07:30 PM
Jigabop's Avatar
Jigabop
Originally Posted by tru35683
looks fine.
BTW you might want to upgrade your fuel system to an airdog or fass system.
and I mean the systems with the filters if your stock filter cant keep up...
airdog filter is a 2 micron filter and can be replaced with fleetguard filters.
Old Oct 23, 2012 | 10:09 PM
iwhitne's Avatar
iwhitne
I've got a fp gauge.. might go with some stage ones 75hp
Old Oct 24, 2012 | 05:18 PM
Jigabop's Avatar
Jigabop
7x.009s will do nicely
Old Oct 25, 2012 | 09:03 PM
iwhitne's Avatar
iwhitne
I'm on a budget.. less than $300?
