1999 2500 4x4 Crusie Control problems Cummins
Old May 22, 2012 | 11:02 AM
mizzourn's Avatar
mizzourn
Angry 1999 2500 4x4 Crusie Control problems Cummins
Alright I have read the post but nothing seems to match what I have going on. I bought this truck and it said it had cruise but the switches on the steering wheel were torn up. Luckily I had a 1998 I was selling that had cruise and it was working. I swapped the switches in the steering wheel, still no light and no cruise. I then read forums and found the vaccum line was broke to the control unit under the drivers side battery. I replaced the vaccum line and still no light or cruise working. Then I swapped the control units (under the drivers side battery) in the trucks and still no light or cruise. I get no lights in dash for Air bag/ 4x4/ abs or cruise, (except at startup). If I read the forums correctly, if the clock spring was bad, then the Air bag light would be on. I have sold my 1998 so now I cannot pillage it any more. This is getting frustrating. One forum mentioned a control sensor and bypassing it to get power to the switches but I don't know where that is. Hope someone can help. Thanks
Old May 22, 2012 | 11:18 AM
Jigabop's Avatar
Jigabop
if you're not even getting the light to come on, then it is not a vacuum problem. its an electronic problem for sure. it would only be a vacuum problem if the vent control and 4x4 didn't work, but the light came on when you turned cruise on. have you already checked the fuses?
Old May 22, 2012 | 05:11 PM
mizzourn's Avatar
mizzourn
Owners manual doesn't list Cruise control in the section with fuses, but as I looked through the fuse listing with components I didn't notice anything not working. I do think your right about being electrical but not sure it is a fuse. I'll pull them all this eve
Old May 28, 2012 | 02:34 AM
00DodgeQC4x4's Avatar
00DodgeQC4x4
I bet your clock spring is bad. That's what was wrong with my 99 CTD Laramie.
Old May 29, 2012 | 04:14 PM
mizzourn's Avatar
mizzourn
Thanks I'll get one ordered and see if that does it. All fuses were ok.
