5.9 6 speed programmer?
Old Jun 16, 2012 | 12:33 AM
catcherpablo's Avatar
catcherpablo
Default 5.9 6 speed programmer?
I have a 2006 5.9l 6 speed and was wondering what programmer would be best
Old Jun 17, 2012 | 12:31 AM
scatpack_69's Avatar
scatpack_69
Best for what?
EFILive or Smarty are the best, period.
Old Jun 17, 2012 | 06:35 PM
catcherpablo
Speed and black smoke
Old Jun 18, 2012 | 02:01 AM
dodgeramguy85's Avatar
dodgeramguy85
A lot of guys are running the EFIlive. Skip the smarty the efi will do better than the smarty anyway
Old Jun 18, 2012 | 03:05 PM
Jigabop's Avatar
Jigabop
smarty or EFIlive is the way to go...might wanna upgrade your lift pump and clutch and throw some gauges on there before you throw one of those on there...it will definitely burn up a stock clutch, and suck fuel harder than your stock lift pump can keep up with...
for gauges I would suggest EGT, Boost, Rail Pressure, and fuel pressure.
fuel pressure is really an optional gauge on your truck (mandatory gauge on a 2nd gen 24v) but you definitely want the rail pressure, boost, and egt gauges. If you had an automatic, I would say trans temp too, but that is also optional for a manual. G56 trans aren't known for overheating because of the aluminum case..NV5600's are cast iron.
