half breed 2001 cummin into 1997chevy
Old Jul 17, 2012 | 09:29 PM
austinkopp's Avatar
austinkopp
Cool half breed 2001 cummin into 1997chevy
I just in stalled this 2001 cummin into my 1997 chevy truck. have every thing hooked up.when I crank the engine it has a sucking noise in the intake,I have never incountered this before. I keeped the VP44 pump and computer. what is the sucking noise. I built one of the beast back in 1996,I used a p-pump on that build up,never had a problem.
Old Jul 17, 2012 | 11:10 PM
Gonna move this to the Diesel forum for you. (if I can.....)
Old Jul 18, 2012 | 02:26 AM
scatpack_69's Avatar
scatpack_69
A sucking noise....loose filter connection maybe? Hard to tell by the description, maybe a video could help?
Old Jul 18, 2012 | 06:58 AM
austinkopp's Avatar
austinkopp
I am having problems on it starting as I crank it over it does not start and I hear a sucking noise from the intake inlet.I was cranking a bit before this sucking noise started.it never did start.the eng is a 2001 cummins w/a VP44 pump. I am not shure what other info you need,leave a list I will get the info for you.thanks
Old Jul 18, 2012 | 08:42 AM
stewie01's Avatar
stewie01
Cummins into a Chevy....
Old Jul 18, 2012 | 01:43 PM
scatpack_69
Is the sucking on the intake to the turbo (passenger side) or intake manifold/horn (drivers side)? I've occasionally had a "sucking" sound that was no more than untightened clamps on the intake to the turbo; I can't think of anything that would cause a sucking sound not related to the air charge system, unless maybe the fuel connection to the VP isn't loose. Even then I'd think there would be a leak.
A separate issue (I think) is the no-fire; did you prime the system by cracking fuel lines at the head? You don't want to starve that VP of fuel, or it's a grand to replace. As long as it has fuel and the VP is supplying pressure, it'll start
Old Jul 21, 2012 | 06:42 AM
austinkopp's Avatar
austinkopp
well i found the problem on the no starting.don't for get to hook up the ground cable on the computer. I have run the eng and it sounds so sweet.So far every thing is coming along nicely gages all work and I have the foot fuel feed working.today is get rid of unwanted wiring under the hood.and The sucking noise in gone after I started it was not there.
Old Jul 23, 2012 | 01:40 PM
scatpack_69
Talking
That helps too!
Old Jul 23, 2012 | 06:55 PM
dlyter09's Avatar
dlyter09
Any pics or videos of this beast?
