help ive got bad vibes
Old Aug 18, 2012 | 05:41 PM
DodgeFreq's Avatar
DodgeFreq
Default help ive got bad vibes
i think i have a u-joint going bad but im not sure. the truck doesn't clunk or squeak but it does get a moderate vibration from 35 mph on up through highway speeds. at first i though it was an out of balance wheel but wouldn't that be a constant vibration, not just while the truck is under acceleration and while its on cruise control? my vibes go away when im decelerating which is what led me to think its the u-joint. basically im wondering if anyone else has had this happen and what the cost/difficulty is to do it myself
Old Aug 25, 2012 | 09:37 AM
hillbilli's Avatar
hillbilli
Could be a u-joint. Best thing to do is jack the rear wheels up and try to wiggle each u-joint and check for play. Also inspect the front driveshaft and axles to.
Old Aug 27, 2012 | 12:58 AM
d40830's Avatar
d40830
Also try checking the CV joint in the front driveshaft. My original was not greasable but when it went the new one has a fitting for a needle greaser(nice)
Old Sep 18, 2012 | 01:15 PM
DodgeFreq's Avatar
DodgeFreq
it was the rear u joint. the stealership wanted 125 for the part and another 150 in labor. napa wanted 33.50 for a better part and even though i could have figured it out i ended up paying 127.50 to be shown the right way to do it so now i can do the others if they go
Old Sep 19, 2012 | 05:53 PM
hillbilli's Avatar
hillbilli
Now that you know, you will be doing it all the time now
Old Sep 20, 2012 | 01:58 PM
DodgeFreq's Avatar
DodgeFreq
yea isnt that always the case
