04.5 5.9 cummins 2.4 valve 4x4
Old Oct 30, 2012 | 04:48 PM
cumminsowner45's Avatar
cumminsowner45
Talking 04.5 5.9 cummins 2.4 valve 4x4
Hey y'all. I'm final a cummins owner always been a big fan just never had the money to afford it. Bought it with 138000, everything stock on it. Only problem is the 4 speed automatic transmission, a little slope downshifting from 2nd to 1st I think. But I knew those transmission built up anyways. I know the basics to most truck but want to learn a lot more. The only mods I'm really interested is increasing mpg and engine life. Not really looking for tons of power. If you guys have any pointers or brands or good deals. With some mods I'm looking for (cold air intake, tuners for mpg/shifting points, exhaust, ect.) I'd appreciate it. I know how to work on the basic of a truck but I don't think I could do much ripping it apart. Right now anyways. So if its something more advanced ill need a little more explaining.
Thanks a lot
Old Oct 31, 2012 | 11:35 AM
Jigabop's Avatar
Jigabop
airdog is good for engine life, so is running ashless 2-cycle oil for lubrication to the injection pump and injectors. 128:1 ratio.
smarty on low levels will help economy, overfilling the transmission by a quart helps transmission life. gauges also never hurt.
Old Nov 1, 2012 | 11:00 AM
cumminsowner45
Thanks. I appricate the info ill look more into the I've read about the two stroke mixer before but I still don't know how I feel about it yet I might try it a couple times c how it work. Ill look into I just order a leveling kit and exhaust. Hopefully have them all up by next weekend
Old Nov 1, 2012 | 11:51 AM
Jigabop's Avatar
Jigabop
airdog fuel system will provide better fuel pressure to your injection pump, removes air from the fuel, and has a water separator and 2 micron fuel filter. filters better than the stock filter/separator does. some people have cracked injectors from dirt making it through their stock filter which wouldn't have happened with an airdog or fass filter unit.
the 2 cycle oil will slightly improve your fuel economy as well as keep your cp3 pump and injectors lubricated. ULSD is very stripped of its lubrication properties compared to LSD (the fuel not the drug). though tests have shown that 2% or higher soy based bio diesel (like soypower B5) has excellent lubricity and does not need additives like the 100% petro diesel does which has horrible lubricity ratings.
Old Nov 2, 2012 | 09:38 AM
cumminsowner45
Thanks you! That very helpfull.
