New member with a problem
Old Nov 11, 2012 | 07:04 PM
Cmechs's Avatar
Cmechs
Default New member with a problem
Hey folks new member here saying hello and hoping someone can help me!
I have a 98 ram 1500 w/a 5.9! Here is the deal there was a diesel trans put into the truck and a 180 degree tstat and the truck will get nowhere near operating temp and the heater sucks because of it?!?!? Please let me know anything I can do? Is the radiator to much for the truck???
Old Nov 24, 2012 | 11:48 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I'll move your post to the Diesel section.
Old Nov 25, 2012 | 05:49 PM
Jigabop's Avatar
Jigabop
Originally Posted by master tech
Welcome to DF
he doesn't have a diesel...
also 180* tstat is too cold... get a 190*+ tstat...higher the better for your heat.
Old Nov 26, 2012 | 08:15 PM
nicetrucker's Avatar
nicetrucker
radiator size and transmission has nothing to do with operating temp. you can have no rad or 5 rads , it dont matter , as long as that thermostat is closed your engine will run at 180. your problem is simple , the thermostat wasnt installed properly , it is not seated or at an angle. it needs to reinstalled. in other words , water is always circulating , you can verify this by removing radiator cap when cold. start engine , you will see coolant circulating inside.
Old Nov 27, 2012 | 07:09 PM
Wombat Ranger's Avatar
Wombat Ranger
Put a stock 195* stat in the truck.
Old Nov 28, 2012 | 03:43 AM
horatio102's Avatar
horatio102
A diesel trans was put in? Are we talking about a manual trans with a removable bellhousing?
Old Nov 28, 2012 | 02:29 PM
dlyter09's Avatar
dlyter09
Either way the transmission doesnt have anything to do with engine temp.. Like Wombat said put a 195 back in and all will be fine
