2001 Dodge "SURGES"
Old Dec 10, 2012 | 03:41 PM
jhen8390's Avatar
jhen8390
Default 2001 Dodge "SURGES"
We have a 2001 Dodge 3500. When it is cold (under 45 or so), it surges and will take off with you and if it's not surging on you, the accelerator won't work. You can push/pump the accelerator over & over and then all of a sudden it will either take off with you or just set and idiol. It never dies or quits running. We have replaced the fuel lines & fuel filters....we have also kept it completely fuel of diesel and added additives. Any ideas???? Someone is going to get hurt or we are going to run into someone or something. When the weather is warm it never does this, only when cold.
Old Dec 10, 2012 | 03:48 PM
dodgetrucker75's Avatar
dodgetrucker75
sounds like you might have a bad apps, (throttle position sensor) try doing a reset and see if that helps (google "cummins apps reset") should be easy to find, check codes, and check all ground wires
Old Dec 11, 2012 | 09:26 AM
jhen8390's Avatar
jhen8390
Thanks! we will try this....
Old Dec 11, 2012 | 01:47 PM
Jigabop's Avatar
Jigabop
yep. sounds like the APPS is dead...reset is a bandaid. when it happens its time to replace...
I hear timbo APPS is one of the best replacements.
http://www.dodgecumminsapps.com/contact.html
and for $165 shipped, not bad.
only do that IF it is the apps that is bad...check the codes first though, that should tell the story of whats going on...these symptoms can also be a failed VP44 injection pump...codes will tell which it is.
Old Dec 18, 2012 | 07:14 PM
Freewater Slim's Avatar
Freewater Slim
Default app surge
I studied forums for two weeks. Finally went to Timbo web page. Ordered apps,
received two days later. one hour install. New truck now!
Old Dec 20, 2012 | 09:21 PM
Freewater Slim
a dead spot in the apps sensor will not always throw a code. Check out the timbo web site. I did and for $165.00 I solved the problem. It's the best money I ever spent.
