Drivers Park Lamp Issue
Old Dec 28, 2012 | 03:38 PM
jameswright903's Avatar
jameswright903
Unhappy Drivers Park Lamp Issue
I have a 2012 Ram 2500 that all of the sudden the left rear park lamp will not come on. Bulb is fine and fuses are fine. used to pop the 15 amp fuse on occasion but the truck has less than 5k miles on it. trying to figure out if it might be just a simple fix or if im gonna have to put all my DPF stuff back on and take it in for warranty.
Old Dec 28, 2012 | 06:06 PM
Uncle Meanie's Avatar
Uncle Meanie
I'm going to state the obvious here. If the fuse blows it is from an overload or short to ground.
Now that the light is not working I will assume that you have checked the fuse and it is good. That means the wire has most likley broke and could be a simple repair. The hard part is locating the break. I would start by pulling the tail light assembly to see if it is back there.
You'll need to follow the wire back to the fuse location, looking for any spot it can be pinched. It's possible that when the 4" lift was installed, the wire loom was compromised. I would do as much as I could on my own before taking it back to the dealer.
Hope this helps.
Old Dec 28, 2012 | 07:35 PM
dodgetrucker75's Avatar
dodgetrucker75
^^^ yup like he said, with the lift or maby the exhaust, somethin probably got into the harness
Old Dec 28, 2012 | 08:28 PM
jameswright903
I'll check what I can in the morning. Thanks
