Might be in the market for a Dodge Cummins 5-Speed?
Old 02-13-2013 | 11:25 PM
horatio102's Avatar
horatio102
On the 94, it says the bad dipsticks caused an underfill.
Old 02-14-2013 | 01:00 PM
Jigabop's Avatar
Jigabop
CAPACITIES
Engine, without filter..........10.0 quarts[1]
Automatic Transmission, 46RE Initial Fill..........4.0 quarts[2]
Automatic Transmission, 46RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, 47RE Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
4 speed 46RH..........10.0 quarts
4 speed 47RE..........17.0 quarts
4 speed 46RE..........13.0 quarts
Manual Transmission, AX-15..........6.5 pints
Manual Transmission, NV3500..........4.2 pints
Manual Transmission, NV4500..........8.0 pints
Differential, with 7.25 ring gear Front..........3.0 pints[3]
Differential, with Dana 60 Front..........7.6 pints[4]
Differential, 2WD with Dana 60 Rear..........6.3 pints[5]
Differential, 2WD with Dana 70 Rear..........7.0 pints
Differential, 2WD with Dana 80 Rear..........6.8 pints[6]
Differential, 4WD with Dana 60 Rear..........7.2 pints[7]
Differential, 4WD with Dana 70 Rear..........7.6 pints
Differential, 4WD with Dana 80 Rear..........10.0 pints
Transfer Case,NP241..........5.7 pints
Transfer Case,NV241HD W/ PTO..........10.0 pints
Transfer Case,NP231, 233..........2.5 pints
Transfer Case,NP241HD..........6.5 pints
that is listed under 94-02 dodge on the xtreme diesel performance site...confirmed by more than one source
of course the dummies are missing the NV5600.. 5Qts (+1 for overfill)
Old 02-16-2013 | 01:26 AM
horatio102's Avatar
horatio102
I'll let you know how much it takes to top off my truck at my next LOF... in a few months (if I remember).
I've always just dumped 3 gallons in (plus an extra quart-ish if I'm draining my FS2500 too).
