Dodge Ram 2500 transmission cooling diagram
I'm new on this forum. My 2500 diesel has a transmission leak and I am looking for a detailed diagram of the whole transmission cooling system. The leak is coming from the water cooled heat exchanger and I want to bypass this through a high capacity after market cooler to be mounted in front of the radiator, which will give me the stock air cooler plus the after market one. A detailed diagram would be very helpful. By the way, the dodge place wants 2100 dollars to replace the heat exchanger. Thanks
Best advice I could give is to stop driving it now. You risk a total failure of the part and it will cross contaminate both the engine & transmission forcing a tranny rebuild and a pain in the *** engine flush. Ask me how I know...
I have bypassed that cooler and have the stock one up front and a remote one mounted under the rear of the cab above the rear driveshaft. That one has a built in fan & fan switch which is still unwired. I have a DD mag tranny pan and never see temps above 180 in the pan... I dont tow either. If I did I'd hook up the fan.
I had a shop do both the bypass & install of the other cooler. I'd imagine bypassing it & adding the remote cooler is pretty straight forward. You should drill out the check valve in the stock cooler up front and flush the debris out.
Trending Topics
ultmately the conversion cost $1800 bux since I had to rebuild the tranny... The day my cooler failed I pulled up the tranny shop for some parts install work. When I saw the strawberry milkshake in the overflow bottle I knew exactly what happened. $600 later & a lot of flushing it was pretty clean of contaminates. That included bypassing the heat exchanger. The other cooler ran me something like $200 bux and about $100 for the install... I mounted that one under the cab near the rear passenger seats just above the driveshaft.
