code 0123
Old May 1, 2013 | 10:57 PM
tirons's Avatar
tirons
Default code 0123
2000 diesel... when a/c is turned on the rpm drops 50 rpm. then has a sharp 150 rpm rise .when this happens it feels like a sudden surge. and i get the po123 code., but it only happens everytime the a/c compressor clutch ingages. po123 is tps/switch a circuit high input. just wondering if my tps could really do something like that. hope some of you dodge diesel boys can help. thanks ........ tom from oregon
Old May 2, 2013 | 07:10 PM
jasonw's Avatar
jasonw
Site Moderator
For future reference:
https://dodgeforum.com/forum/dodge-r...s-section.html
Old May 3, 2013 | 12:10 PM
Jigabop's Avatar
Jigabop
ever have any dead pedal or anything? and do you have any kind of programmer on it?
Old May 5, 2013 | 09:46 PM
tirons's Avatar
tirons
no never any dead pedal and never any programer. really strange problem huh!!!!!!!!
Old May 12, 2013 | 05:28 PM
hillbilli's Avatar
hillbilli
check the power cable going to the compressor, they are known to run up against the engine or frame and ground out when the compressor engages causing the symptoms you described.
