2005 dodge 3500 bullydog diagnostic codes...HELP PLEASE
Old May 16, 2013 | 11:22 PM
CourtneyHart's Avatar
CourtneyHart
Question 2005 dodge 3500 bullydog diagnostic codes...HELP PLEASE
I need help figuring out what some codes are..while sitting still it started cutting out..after running the diagnosic scan water in the fuel light came on. then went off after I pulled out.. but these codes still showed..please help
p3222
p3703
c2902
c0101
c1221
b1306
Old May 18, 2013 | 12:33 AM
lxman1's Avatar
lxman1
Site Moderator
Those are some strange codes. You might try a different scanner.
I have also moved this to the diesel section to see if you can get better results.
C codes are usually Chassis and B are Body I believe. p is powertrain.
