obd codes pertaining to fuel problems
Old 07-22-2013, 07:02 PM
rodnok's Avatar
rodnok
rodnok is offline
Default obd codes pertaining to fuel problems
My truck is popping 2 codes when it wont start or stalls. P1689 and p1693.
Can anyone shed light on the problem I am having.
98.5 5.9 cummins
Old 07-23-2013, 12:36 PM
Jigabop's Avatar
Jigabop
Jigabop is offline
1689 is one of the death codes for the vp44... (associated with vp44 electronics failure)
but it could also be caused by a bad ecu, or a bad fuel system relay, bad drivers side ground, etc...
I would check the ground and the relay first.
1693 means there is another code in the PCM that you will need a code reader to retrieve.
Quick Reply: obd codes pertaining to fuel problems
