2001 cummins 4x4 Front seat electric connector
Old Jun 3, 2014 | 09:20 PM
ARTISAN's Avatar
ARTISAN
Default 2001 cummins 4x4 Front seat electric connector
I got the above truck, 2001, 2500, diesel extened cab just about completely redone, the only problem was the driver front seat, wore on front left corner, so I bought one on-line thru one of those junk yard national connections, they said it was in 95% condition...it arrived and the same dam area was worn thru also...to return it would have cost as much as the seat...so I called around local no luck and went back onto the national salvage sites and found another which they said was 99%..so I bought it, and again I got the shaft the same front left corner of the seat is worn thru and sags like the other 2 I now have.
But this isn't my problem... I am putting seat covers on the best one until I can find one locally and see it before buying it...
What started my endeavor with the driver seat was that a year before I decided to clean up repaint and go thru the truck mechanically the wiring connector that comes through the floor board started to burn, luckily I had a fire extinguisher and got the small fire out, but the electrical connector from thru the floor board is fried, I looked thru the 700 + pages in the parts catalog and they only give the entire front seat wiring harness, is there a schematic that I can use to just wire the harness directly to the main wires on the power seat out there? I would use the connectors that can be opened and closed a few times to do the connecting of the wires, but I can not tell which color wire coming thru the floor board went to what pin on the seat connector, due to they both got fried, the one thru the floor more so and I don't want to wire her up wrong and end up frying the seat motors..any help would be appreciated...Thanks again...
Kurt
Last edited by ARTISAN; Jun 3, 2014 at 09:27 PM. Reason: missed that the truck was a 2500
Old Jun 3, 2014 | 10:39 PM
00DakDan's Avatar
00DakDan
Section Moderator
I'll move this thread to the Cummins section.
Old Jun 4, 2014 | 07:58 AM
ARTISAN's Avatar
ARTISAN
I wasn't sure if a non-engine issue was in that section or not...thank you for taking the time.
