2 issues that I need help with, thank you in advance!
Old Sep 9, 2018 | 09:55 PM
Hodge86's Avatar
Hodge86
Default 2 issues that I need help with, thank you in advance!
I have a 2001 Dodge Ram 2500 4 X4 with the turbo diesel and a 6-speed manual transmission.
now the first issue is that when I am in two-wheel drive and I turn sharp to the left or right it feels like my front end is trying to engage and it hops my wheels. My steering wheel will jerk to the left and right depending on which way I'm turning. So if I am turning sharp to the left the steering wheel will slightly jerk to the right vice versa.
And the second issue I am having is when I'm driving in 2 wheel drive. My front end will do a clacking noise when I am in 3rd and 4th gear. It sounds like I have gears that are slipping but I have taken the pumpkin off and checked my gears and everything looks great nice and tight there's no chunks or shavings nothing everything looks beautiful. I have checked my actuator and everything seems to be functioning just fine.
Details on work done: I have had old ball joints replaced and had the front end about 80% rebuilt just to get it aligned. There is a slight vibration when I'm going 60 to 70 miles an hour. I have a brand new steering box installed. And I am losing for in my transfer case.
Thank you for your time and I hope you guys know something that I don't.
Old Sep 10, 2018 | 12:55 AM
primem's Avatar
primem
if the front axle ujoints are bad; when turning it will feel like the drivetrain is binding up... as if you are in 4wd turning on dry pavement. bad ujoints will also cause a vibration at highway speed.
Old Sep 12, 2018 | 08:30 PM
Hodge86's Avatar
Hodge86
Thank you! I'll definitely look into that.
My 4wd keeps engaging every now and then and that's when the wheels jerk when I'm turning. like just now pulling into a parking spot it started to jerk the wheel and now I can't get the transfer case into neutral or for high. Does that sound like an actuator problem or my transfer case itself is screwing up? And would that cause the wheels to jerk?
Old Sep 15, 2018 | 08:27 PM
nibroc's Avatar
nibroc
you might be partially in 4X4
Old Sep 16, 2018 | 01:06 PM
Hodge86's Avatar
Hodge86
I'm thinking that since my transfer case is messed up that the vacuum lines are getting proper air flow and that is causing my actuator to engage every now and then. Does this sound like a good theory?
Old Sep 16, 2018 | 01:29 PM
Here is a nice diagram on how it is suppose to work...... Vacuum leaks, or bad vacuum switch may cause your problem....
