2012 2500 starting issue
Hi, I have a 2012 Ram 2500 Diesel. The problem I am having is, it won't start sometimes. What happens is, when I turn the key to the on position, the wait to start light should appear in the middle window at the bottom of the gauge. Instead it shows the low fuel light(gaspump) then service 4 wheel drive light. I forget what shows in the left window. Normally the ETC light shows here. Also under normal conditions, I am able to hear something energizing under the hood. This doesn't happen when the wrong lights show up first. Now if I turn the key to Acc then back on, 9 times out of 10 it will go to through the correct functions. I went to local dealer and they had me replace the Anti-Lock Break Module. This didn't work. When I went to bring it back, I used my wife's key. It didn't have the issue. So the dealer reprogramed the keys and the truck. This worked for awhile, now it is doing it again. I am tired of throwing money to the dealer. I don't think they now what is going on. Any ideas would be appreciated.
I noticed this is happening when the wrong sequence occurs. I can shift the truck out of park without stepping on the break pedal. When the correct sequence occurs. I cannot shift without stepping on break. Now this is when the key is in on position only . Not started!
