Temp gaue 2000 ram 5.9 cummings not working
Old Jan 19, 2021 | 08:23 AM
raymozingo's Avatar
raymozingo
Default Temp gaue 2000 ram 5.9 cummings not working
Just replaced radiator thermostat and coolant temp sensor. Getting a P0118 code. Checked voltage on sensor wire and getting 5.45 volts. I know it's suppose to be around 5 v. Ground is .5 ohms. Checked connections cleaned and made sure none were bent or damaged. Wire looks goodHad a ck engine light but when I made sure the connection was tight it went out????? Any help will be appreciated .
Ray
Old Jan 19, 2021 | 09:30 AM
That is voltage high..... So, a short somewhere?
If the lite went out, did the gauge start working properly?
Old Jan 19, 2021 | 03:07 PM
raymozingo's Avatar
raymozingo
Default No gauge still not working. Where do I start looking for short?
No still not working . Where do I need to start looking for short? just about done with spending money .
Old Jan 19, 2021 | 09:28 PM
The way it works is, the PCM sends a 5 volt signal to the sensor, sensor is just a variable resistor, don't remember if resistance goes up or down with temp...... If you have a scanner that can read live data, see what the PCM thinks engine temp is, start wiggling the harness between the sensor, and the PCM, until it changes. (don't even need the engine running.) That will get you rather close to where the problem is.
Old Jan 19, 2021 | 09:36 PM
raymozingo's Avatar
raymozingo
Thanks I will try that.
Ray
