07 5.9 nv273 install issue
Old Oct 7, 2021 | 11:32 PM
5.9 Cummins's Avatar
5.9 Cummins
Default 07 5.9 nv273 install issue
Truck in gear, won't move. Grinds going back into park
Old Oct 8, 2021 | 09:59 AM
T-case in neutral?
Old Oct 8, 2021 | 08:40 PM
5.9 Cummins
T-case in neutral?
As far as I know. Not on the selector dial
Old Oct 8, 2021 | 08:47 PM
5.9 Cummins
I purchased a salvage nv273. When installed, there was no result from turning the 4wd dial. Then the grind going back to park.
I then pulled the shift motor off the replacement and swapped it with the one off the old tcase. Now it makes a noise when switching 4 high on but only flashes in 4 low. Still grinding when returning to park.
Old Oct 9, 2021 | 10:10 PM
00t444e's Avatar
00t444e
Should have put an NV271 in, that solves all of those goofy problems.
