Column shifter removal
Old Oct 22, 2021 | 01:26 PM
2005ramm's Avatar
2005ramm
Default Column shifter removal
2005 3500. I’m swapping columns for this truck and have everything apart besides the shifter linkage. Where is the best place to seperate it at? Does it just pry off?
Old Oct 22, 2021 | 01:30 PM
I would think at the base of the column, not the lever itself.
Old Oct 22, 2021 | 01:42 PM
2005ramm's Avatar
2005ramm
The only other release methods I see are 2 white clips. Ive released both of them and still cant get it out.
Old Oct 22, 2021 | 04:08 PM
Why are you changing the column?
No idea how those come off.... this is where the service manual would come in handy.
Old Oct 22, 2021 | 06:59 PM
2005ramm's Avatar
2005ramm
there is play in it. I can turn the wheel without the output shaft that meets with the u joint moving.
Old Oct 23, 2021 | 09:55 AM
Can you disconnect the shift cable from the other end, and just take it out with the column?
Old Oct 25, 2021 | 11:39 AM
2005ramm's Avatar
2005ramm
I can try but the new column doesnt come with a cable. So it will have to come off either way to swap to the new one
Old Oct 25, 2021 | 04:04 PM
There a video on youtube for how to change it?
