So long as whatever you use can stand the heat of the engine compartment...... It would be a real bummer to have it quiet for a bit, then burn to the ground.
Is the original insulation still attached to the hood?
original insulation is still in place, but the truck is extremely loud, but sounds like all the other Gen 2 diesels. i'll check on the heat issue...good point.
