band adjustment specs on 05 ctd
Old May 20, 2007 | 10:14 PM
DBLR's Avatar
DBLR
Default RE: band adjustment specs on 05 ctd
ORIGINAL: sallyman1
what amsoil are you running in tranny and diffs? could i get the name of it or the viscosity? Is amsoil good in a dodget ranny? i heard only atf+4.
I have used Amsoil AFT in every Dodge transmission I've owned for the past 7 years with out any problems. I also used Amsoil 75/90 Severe Gear Oil in my diff's and if tow a lot you could also use either 75/110 or 75/140.
Old Nov 12, 2007 | 08:41 PM
adam05's Avatar
adam05
does any one have the band adjustments for dummies I set mine to the specs and the damn thing wouldn't move, curious as to the thread on the adjustment screw is it left or right hand thread
Old Nov 12, 2007 | 08:50 PM
Parts/Service's Avatar
Parts/Service
Factory specs, but use at your own risk....
For a 2005 48RE....
I accept no responsibility if you damage anything
ADJUSTMENT - BANDS
FRONT BAND
1 - LOCK-NUT
2 - FRONT BAND ADJUSTER
The front (kickdown) band adjusting screw (2) is located on the left side of the transmission case above the manual valve and throttle valve levers.
[ol][*]Raise vehicle.[*]Loosen band adjusting screw locknut. Then back locknut (1) off 3-5 turns. Be sure adjusting screw turns freely in case. Apply lubricant to screw threads if necessary.[*]Tighten band adjusting screw to 8 N·m (72 in. lbs.) torque with an appropriate Torx™ socket.
CAUTION: If Adapter C-3705 is needed to reach the adjusting screw, tighten the screw to only 5 N·m (47-50 in. lbs.) torque. [*]Back off front band adjusting screw 1-3/4 turns, for diesel vehicles, or 1-1/2 turns, for V-10 vehicles.[*]Hold adjuster screw in position and tighten locknut to 34 bN·m (25 ft. lbs.) torque.[*]Lower vehicle.[/ol]
REAR BAND
1 - LOW-REVERSE BAND ADJUSTMENT
The transmission oil pan must be removed for access to the rear band adjusting screw (1).
[ol][*]Raise vehicle.[*]Remove transmission oil pan and drain fluid.[*]Loosen band adjusting screw locknut 5-6 turns. Be sure adjusting screw turns freely in lever.[*]Tighten adjusting screw to 8 N·m (72 in. lbs.) torque.[*]Back off adjusting screw 3 turns.[*]Hold adjusting screw in place and tighten locknut to 41N·m (30 ft. lbs.) torque.[*]Position new gasket on oil pan and install pan on transmission. Tighten pan bolts to 17 N·m (13 ft. lbs.) torque.[*]Lower vehicle and refill transmission with Mopar® ATF +4, Automatic Transmission fluid.[/ol]
Old Nov 12, 2007 | 09:35 PM
adam05's Avatar
adam05
thanks some how I couldn't get 72 in. lb. out of mine so I might have to pay some body else to screw it up
