intake baffle
Old Mar 31, 2006 | 02:56 PM
backhoebob's Avatar
backhoebob
Default intake baffle
help! I have an 02 2500 4X4 3.54's.5 spd, is there an intake baffle on it? if so, where is it? i removed the silencer ring & i couldn't hear any diff. Also-my speedo & odom doesn/t work-i can't find where it plugs in. it's not on the trans, trans case, or rear. any one know where it is? or which fuse it is? thanks mucho.
Old Mar 31, 2006 | 11:46 PM
Drew's Avatar
Drew
Default RE: intake baffle
the intake baffel is going to be in the hard plastic down tube between the filter and the turbo. you can cut the ends off and the middle will fall right out.
as for the speedo, either you have a gremlin in the computer, of the pigtail in the dash came loose.
Old Apr 30, 2006 | 11:50 PM
derrelw's Avatar
derrelw
Hey guys I'm new to this and don't know where the "downtube" is. Does anyone have a picture?
BTW I just bought a 1999 2500 4x4 CTD SLT w/ Banks programmer and 4" exhaust.
This thing FLYS!
Old May 2, 2006 | 10:10 AM
Drew's Avatar
Drew
ORIGINAL: derrelw
This thing FLYS!
most likely yours is already MIA
Old May 2, 2006 | 11:48 AM
derrelw's Avatar
derrelw
Thanks for the reply. I'm guessing that the "downtube" isn't up / down it's just downstream from the airbox.
BTW my rig is an automatic and the gear indicator on the dash doesn't work. Any ideas?
Old May 2, 2006 | 02:57 PM
Drew's Avatar
Drew
with your 99 I believe the tube makes a 180 bend from the air box to the turbo. the 03's to present have two 90 degree bends between the air box and the turbo and the section between which is hard plastic had some baffeling in it to decrease noise.
with the indicator, I would check the connections behind the dash and make sure they havent corroded/come unplugged
Old May 3, 2006 | 11:38 AM
derrelw's Avatar
derrelw
Thanks Drew. I checked the downtube and its wide open. I"ll look under the dash to check for loose wires.
