Gear ratio
Old Apr 14, 2006 | 12:44 PM
hancockbs's Avatar
hancockbs
Default Gear ratio
How do I figure out which gear ratio I have. I can't seem to find it on the invoice anywhere.
Old Apr 14, 2006 | 12:53 PM
dieselram's Avatar
dieselram
Default RE: Gear ratio
Check the info panel in your glove box. Mine was attached to the box door and listed the various specs. If you have a newer manual 2500, you have 3.93 gears because the 6spd ratios balance it out to an auto with 4.10 gears.
Old Apr 14, 2006 | 01:05 PM
Drew's Avatar
Drew
if you have an 06 the build sticker in the glove box is missing.
Shaun has it with the G56 only having 3.73's, but the auto with 3.73's will run around 1900 or so RPM, with 4.10's you'll be turning around 2200RPM at 70mph
Old Apr 14, 2006 | 01:31 PM
dieselram's Avatar
dieselram
Why did I type 3.93? Brain can't keep up with the fingers.
Old Apr 14, 2006 | 02:49 PM
Drew's Avatar
Drew
I saw it at 3.73 myself
dislexia kicking in good today[:@]
Old Apr 16, 2006 | 12:01 PM
gametrail's Avatar
gametrail
I have a 06-3500 DC-6 spd.. I was told when I got it that it had 3.73 gears. But now I think it has 4.10 because I am runing about 2200 @ 70. Drew said that was 4.10 right ?
Old Apr 18, 2006 | 10:14 AM
Drew's Avatar
Drew
no, the G56 has shorter gears so when you are in 6th you are running a .79, my NV5600 is running a .76(I think) so when it comes down to it my NV5600 with 4.10's is turning the same RPM's as your G56 with 3.73's
Old Apr 19, 2006 | 01:02 AM
HemiMan4451's Avatar
HemiMan4451
If you don't have the sticker in the glovebox, shouldn't it say inside the door if I'm not mistaken?
Old Apr 19, 2006 | 11:04 AM
Drew's Avatar
Drew
ORIGINAL: HemiMan4451
for some reason the 06's done even list the diff ratio on the window sticker
Old Apr 19, 2006 | 02:08 PM
sluff's Avatar
sluff
Same problem with 06 and my service mgr used last 6 0r 8 numbers from the vin code to do look up. If it has 4.10 it would be an extra on window sticker if equiped with auto.
