temp senser? where is it
Old Jun 28, 2006 | 11:51 PM
dlh417's Avatar
dlh417
Default temp senser? where is it
I just bought a 94 ram 2500 4wd it needs the temp senser replaced. I bought one at the local auto zone but cant find where it is on the motor? dodge said its on the pass front side of the head, dont see it anywhere.
Old Jun 29, 2006 | 10:40 AM
Drew's Avatar
Drew
Default RE: temp senser? where is it
she's a tiny little booger. you will see two wires comeing off the head at the front passengers side where the coolant goes into the head.
Old Jun 29, 2006 | 10:57 AM
dlh417's Avatar
dlh417
the one i bought is a little bugger but i still cant find any wire or senser by where the therm housing is?
Old Jun 29, 2006 | 12:58 PM
Drew's Avatar
Drew
it actualy screws into the head.
I can take a pic of it tonight when I get home if needs be
Old Jun 30, 2006 | 01:48 AM
dlh417's Avatar
dlh417
ok broke over and took it to the dealership they looked at it scratched their head, the senser is not where it should be. on a very few early 1994 models { mine is 11-93 } the temp senser is on the driver side of the block under the fuel filter. now i just have to figur how to reach it without taking out the inner finder? maby thats why they repositioned them. thanks for the help hope this help someone else. dlh
Old Jun 30, 2006 | 10:54 AM
Drew's Avatar
Drew
interesting. . .now I know. . .I wonder if that was a take over from the 89-93 VE pump engines. . .hhhmmmmm
I have a pic of mine
[IMG]local://upfiles/7365/238A025D591D43C0A85680F9AC06C438.jpg[/IMG]
Old Jun 30, 2006 | 05:22 PM
dlh417's Avatar
dlh417
thanks for the pic, mine has the same head, the hole where your senser is has a plug screwed in on mine, also the sending unit on mine is not the same as is on most, its about as big around as a quarter. havent made it back in to trade it at auto zone but i figure its the same as a 1993. fortunatly when i went to change it i found that the senser wire was broken, quick fix now temp guage works like a charm Thanks dlh
Old Jun 30, 2006 | 05:39 PM
Drew's Avatar
Drew
the head where the bolt and fitting holes go have remained the same through the years, the main change to the head was in 98 when two more valves per cylinder were added.
what would be sweeet to see would be a 12 valve CR engine.
