lift pump surgery part 2
Old Jul 13, 2006 | 03:05 PM
max39's Avatar
max39
Default lift pump surgery part 2
Still working on replacing my lift pump. Starter is out and this afternoon I hope to finish this. The service manual says :
"Disconnect fuel line quick-connect fitting at
fuel supply line (Fig. 57) at rear of pump."
This "quick-connect" fitting is new to me. How do you disconnect it?
Thanks.
Old Jul 13, 2006 | 03:47 PM
Drew's Avatar
Drew
Default RE: lift pump surgery part 2
you have to feel around a bit, but you are looking for two tabs on either side of the tube. squeeze them together and pull. it should come out.
here is a pic I found that should give you an idea
Old Jul 13, 2006 | 03:49 PM
steve05ram360's Avatar
steve05ram360
go to the 2nd gen forum and at the top there is a Merry christmas thread... download the manual and have a look at it. i started looking thru it to see if I could find what your trying to disconnect but couldnt find it easily...
on the gasers there is a tool you use to pop off the fuel line. it releases a spring that holds the line on so the connector can slide off the rail.
OK, nevermind... someone deleted the thread with the manual in it.
Old Jul 13, 2006 | 11:49 PM
max39's Avatar
max39
I finished changing the lp. I very much apprieciate the help here. The only gotcha I experienced was bleeding the system. I loosened the banjo bolt going into the ip a little too much and made a mess when I bumped the starter.
Thanks
