recall
from what i know all 3rd gens have thrdr roll over valves, but right now the only ones recalled are the 06's? whichdon't make sense to me. Last night i looked under my tuck to check these valves out, mud,gravel, and dirt caked all around them.so i blew them of with an air hose and install some 5/16" fuel line to them and routed the line along the fram, out of the mud water and dirt, this may be over kill but also put a filter on the end of the fuel just to be sure nothin more gets in the fuel tank, some day when i have time...... i'd like to drop the tank and make sure its nice and clean. I just wonder what DC is thinking some days when recall like this??? would also be curious as what there great fix to the problem would be, maybe the horn will start honkuing when your fuel filter gets plugged[:@]
Don't put this one off! My 2006 Quad Cab CTD is in the dealer now and they said they may have to replace at least the head and maybe the motor. They said the rollover valve allowed to much junk in the fuel and there was rust on the injectors. Cummins is having them run some tests and if it passes they will install an entire new fuel system and probably a head, if it fails new motor. Seems far fetched, I couldn't believe what I was hearing, but they showed me all the bad parts and gave me a loaner car for the weekend. They said I couldn't have done anyhing to prevent it.
this is where I found out about hope it works? http://dieselram.com/ubb/ultimatebb....=000593#000003
