Diesel Rollcall...
Subscribe
Jan 14, 2011 | 10:01 PM
  #451
My name's Glen
Layton, Utah
'05 5.9 Cummins
Big Horn Edition
QCSB
6 Speed
90,000 miles
PPE Xcelerator chip
K&N Intake
4" lift 18" rims wrapped with 35 x 12.50 cooper discover MT's
exauhst temp and boost pilar gauges
i'm 27 and have wanted a cummins pretty much my whole life and after 3 years of lookin for a 6 speed i finally got my cummins!
Reply 0
Mar 8, 2012 | 12:46 PM
  #452
Dave here.
I've spent most of my time in the 2nd Gen Forum since I just bought a '99 Ram Laramie 5.2L as an everyday truck.
My Cummins truck is an '04.5 Single rear wheel 3500 4-door long bed that I've had about 4 years now. Other than changing a water pump (super easy!) I've had zero problems.
Auto Trans with 3.75 rear.
All stock except cool blue hose set and Smarty Jr. on the 70hp Tow setting. Speedo adjusted to be spot-on with GPS. And I added Nasta stainless side-steps.
It's a hot-rod when I need it to be!
Reply 0
Jun 11, 2012 | 04:48 AM
  #453
my truck..
Eastern Oregon area...
2007 Ram 2500 QC long box purchased NEW Now 110K on it, no problems at all, never had to take it to a shop!!!
4x4 auto CTD. 600B series running delo synthetic since 75K miles...
triple clutch torque converter, shift kit, self installed also running synthetic trans oil..
Rev teK 6" long arm suspension lift,
KHC "Fuel Boost " black alum 17" wheels, with 35" mudterrains
Stock Exhaust.
Diablo sport plug and play tuner.
Cold air intake
Rhino lined bed and rocker panels.
"hide A goose" goose neck hitch for the 53' GN flatbed i pull...
HD Rear reciever for the 36' toyhauler (bumper pull) on the weekends.
I get 22-26 MPG empty highway, (5 over the limit)
16 towing the GN when empty, 13 when loaded.
14.5-16MPG when towing the toyhauler, loaded or empty
Reply 0
Jun 11, 2012 | 11:44 AM
  #454
name is Ken
truck is in my sig, but heres the list anyway:
2000 Ram 2500 Sport 4x4 quad cab short bed
24v cummins SOVP44
4.10 gears, D80 posi rear
2" leveling blocks
315/75R16 BFG M/T KM2's on centerline wheels
5" straight pipe exhaust with full 5" downpipe
DDP 7x.010 (150hp) injectors
ARP head studs
S357 over S475 compound twin turbos (makes 65psi boost on the street, EGTs never over 1350 with box set to kill WOT to redline in 6th, no defueling)
Quadzilla Adrenaline with pulse monitor mounted on the pillar
Isspro 60psi and 100psi boost gauges mounted on the pillar. 60psi reading boost from the S400 charge pipe, 100psi gauge reading combined boost from a boost bolt in the intake manifold
DiPricol Optix mechanical fuel pressure gauge on column mount
AirDog150 fuel system
Vulcan liberty fuel canister with draw straw V installed
borgeson hi flow steering pump
DT Pro Fab track bar
2012 Ram T-steering swap
Carli low-mount bilstein 7100 steering stabilizer
South Bend 3600# double disc clutch
South Bend HD clutch hydraulics
posi-lok cable for manual front axle engagement control
NV5600 1 3/8ths input shaft 6-spd
trans-cool tranny coolers
vulcan intercooler boots and spring clamps
valve cover, alt bracket, tstat housing, cold pipes, and intake horn powder coated
towing package, hide away goose neck hitch in bed, 55w aux backup lights
spray in bed-liner
leather interior with heated power seats
1000w 4 channel amp
300w sub amp
10" pioneer sub
in dash pioneer DVD/GPS navigation
4' firestix CB antenna with fender mount
cobra 29 LTD classic CB modified to 24w transmit power
Last dyno run was 538hp 1078tq @ rear wheels
think that's it?
Reply 0
Jun 16, 2012 | 08:46 PM
  #455
dave here from alberta ,,i no a little about diesel cummins ...lol
Reply 0
Jun 24, 2012 | 01:39 PM
  #456
Back from the dead with a new 2012 2500 Diesel in Alberta.
Completely stock. Except for debadging and Tint.
Reply 0
Jun 24, 2012 | 07:23 PM
  #457
Names Kevin
05 Ram 3500 4X4 cummins
Phatshaft 66 silver bullet and is compound over a S474....., 120HP injectors from Industrial Injection, Air Dog 215GPM, Dargon fire pump,ARP head studs, ATS Pulse flow 2Pc exhaust manifolds, South bend Double disc clutch, Ats intake manifolds,AEM Brute Force intake ATS Intercooler, and a smarty TnT tuner. And dual CP3s as of a few months ago. Sure i left something out shes my baby!
Reply 0
Jul 3, 2012 | 07:53 PM
  #458
Name is michael 20 and live in central,pa
Recently moved from dakotas into a 2500 cummins. My tranny went in the dakota so thought it was a perfect opportunity to upgrade!
Spent 3 months looking for my baby
02 2500 4x4 6 speed Laramie SLT 39k on my cummins replaced under warranty 141k on the truck. Previous owner was the service manager for a dodge dealer(why the engine got replaced before warranty ended lol)
Truck has
South bend dual disk 3600 clutch
Edge juice w/att
AFE intake
Silver bullet 66 turbo(bit laggy since it doesnt have sticks.... yet)
5in straight pipe
20% window tint
anzo projectors with 55watt hid's along with 35watt hid fogs
Fass 150
2.5in leveling kit with brand new 33's
Rhino Liner in the bed and the entire underneath is sprayed with it.
Absolutely no rust anywhere on it
The mods are on the stand still till I pay a little bit more of this truck off!!
Reply 0
Jul 4, 2012 | 03:57 PM
  #459
Quote: South bend dual disk 3600 clutch
Edge juice w/att
AFE intake
5in straight pipe
Fass 150
ouch a 66 on stock injectors? on an HOVP44 too...yikes! that's gotta lag like a pig if it ever spools at all?!
I would seriously consider ditching that turbo and going with something much much smaller...like a S300G, or super b single...
throw some 75-100hp injectors with it and it'll be quite a responsive truck.
150hp injectors with a 62/71/14 be another good combo.
a 66 is going to need 7x.014 injectors (250hp+ comp) to get it to actually spool enough to be worth while..and that will make your fuel economy go to hell quick. that size injector hazes at idle and smokes a lot.
your VP44 is going to hold you back quite a bit too being a high output vp44....the term high output is anything but... HOVP44's have smaller fueling plungers so they make higher pressure but flow lower volumes of fuel. So stock vs stock they are 10hp more than the standard output, but when it comes to adding wiretap fueling to the pumps and running bigger injectors, the HOVP44 will actually make 100hp less than the SOVP44. HOVP44's have trouble breaking into the 500hp range without using 250hp injectors, where a SOVP44 can do it with 150hp injectors...
just food for thought... if your vp44 ever dies, I highly recommend replacing it with a standard output VP44, which is capable of supporting up to 650hp on fuel only. if you want higher than that, go with dragonfire or monster II vp44 for fueling up to 980hp on fuel only, or convert to P7100.
Reply 0
Jul 4, 2012 | 07:33 PM
  #460
Quote: ouch a 66 on stock injectors? on an HOVP44 too...yikes! that's gotta lag like a pig if it ever spools at all?!
I know it sucks the last owner put it on there not sure why cause he towed 5th wheel with it. I do wanna switch to something but dont have the cash to spend on the turbo. Its alright for now it pulls pretty hard once it gets going.
Reply 0
