1996 12v
Old Sep 30, 2006 | 04:15 PM
9612v's Avatar
9612v
Default 1996 12v
i just bought it. the truck is bone stock. i have almost all of the service records for the truck so i know its been taken care of. it has 235000 on it what would you recemond for so upgrades to get better fuel ecomony and more power for when i tow my jeep? i'm on a pretty tight budget so i want the best bang for my buck
Old Sep 30, 2006 | 08:26 PM
Drew's Avatar
Drew
Default RE: 1996 12v
#1, pull the valve cover off and check the valve lash, .010 intake, .020 exhaust. if it hasnt been done yet.
#2. if you look at the injector pump there will be an 8mm allen screw. pull that off and then you will see in there a star wheel, crank that bad boy up a little bit it will give you more power. next would be heading over to TST and picking up a boost elbow, and a #100 fueling plate.
all these thigns will give you better power to tow your jeep, but your mileage might go down a bit.
Old Oct 1, 2006 | 02:34 AM
racer9's Avatar
racer9
If it hasn't been done, tab the KDP. Get some gauges on it, slide the fuel plate forward, 3K GSK, 4" exhaust, boost control, bump the timing to 15*. If it's an auto, a performance torque converter works wonders, although at that mileage I'd rebuild/upgrade the trans, while it's out.
Old Oct 1, 2006 | 05:22 PM
9612v's Avatar
9612v
its an auto, whats the easist why to get out the button head bolt that hold the fuel plate on
Old Oct 1, 2006 | 07:09 PM
racer9's Avatar
racer9
I used a Dremel tool and ground it off, then with the AFC out of the way unscrewed it with vise grips. Just put a rag in the hole to keep chips out. You're supposed to be able to drive a small torqz bit into it and unscrew it that way, but I couldn't make that work. Lots of info here; http://www.cumminsdatabase.com/read.php?id=58
Old Oct 4, 2006 | 09:36 AM
9612v's Avatar
9612v
what would you all recemond for and exahust system for it? from the tubro back and no cat
Old Oct 4, 2006 | 10:24 AM
Drew's Avatar
Drew
if you can go full 4 inch from the turbo back your engine will thank you. your EGT's will go way down and you wont sacrafice performance.
Old Oct 4, 2006 | 02:24 PM
Mayfair's Avatar
Mayfair
Isn't your truck the same year adn model as Diesel Demon's ? If it is, your in luck ..... BIG TIME !!! Not only does it seem as though he's done a ton of mods, but he's also very willing to share his experiences and knowledge here.
Today just may be your lucky day my friend !!
