turbo upgrade witch 1
looking 2 up grade my turbo got a 06 with ppe programer intake and exh looking 2 do injectors and water meth whats a good turbo still want good spool and able 2 pull a trailer. looking into a edge or maby a phatshaft 62 or somthing like that maby twins
how well does the superb spool up? I know i'm going to need an upgrade sooner or later (could probably use it now), I'd want one that still spools easily on the low end but will flow enough for the top end. I'm figuring i'll be stopping around the 450 rwhp mark, not building a race truck, just a hella strong tower/daily driver...
what about the ATS aurora MST?
I havent looked at that turbo, but the super B spools just like stock, but flows up to 450 I think. if your looking at 450 your best bet might be the SPS64/14 since your wanting to keep towing abilities.
hahahaha... yeah your right. still have the aero to go on, started the guage install last night (got the boost done) and the VB goes in Fri/Sat...
Trending Topics
the 14 is refering to the turbine houseing to help in getting the turbine and compressor wheel spooled up quicker.
the stock one is 16mm I believe, shrinking this down 2mm will force the turbo to spin up quicker since you are shoveing the same exhaust through a smaller hole. you can go 12, but that would be VERY restrictive and you would probably peg 30+psi in a matter a miliseconds
