Question about '03's...
Old Oct 3, 2006 | 09:28 PM
steve05ram360's Avatar
steve05ram360
Default Question about '03's...
did the SO motors have the VP44?
Old Oct 3, 2006 | 11:10 PM
jakebrake's Avatar
jakebrake
Default RE: Question about '03's...
03 is when they swapped to the common rail.
Old Oct 3, 2006 | 11:18 PM
steve05ram360
yeah but they had a standard output motor which had 235 or 250 HP, a carry over from the gen 2 truck as well as the 305 motor. so I just was curious as to the injector pump on the older motor... I'd expect it to be the VP44...
Old Oct 4, 2006 | 12:07 AM
jakebrake's Avatar
jakebrake
Most likely it is the vp44. Drew will correct me if I'm wrong
Old Oct 4, 2006 | 10:12 AM
Drew's Avatar
Drew
all 3rd gen 2/3500's are common rail. yes there were HO's and SO's but they all were HPCR's. the 2/3500's were a little late in the body style change over, DC did this to match when the new engines would be dropped in.
the programming on the SO's is very strange and alot of programmers have a hard time replaceing it, however you can still get some good upgradeable power out of them.
Old Oct 4, 2006 | 01:42 PM
steve05ram360
wow so it sounds like the '03's with the SO motor might be a unique setup... IIRC, the '04's dropped the SO motor
Old Oct 4, 2006 | 02:07 PM
Drew's Avatar
Drew
04.5 is when the SO's went away, mainly since CARB certified the 325 with the cat so there was now only one engine instead of two or three since cali had their own engine. the 03 and 04's were definately a breed of their own.
Old Oct 4, 2006 | 02:17 PM
steve05ram360
cool, better to know this info if Jim (co-worker) asks which one to get... if I can sway him over to the right side... CTD and away from the powerjunk and duracrap...
