Help! Stipped oil drain plug threads!
#21
#22
ORIGINAL: Mayfair
WOW
It is because of this incident that I decided to start learning how to work on my Ram myself.
WOW
#23
May or may not be a long term fix, never done it myself, but have talked to a few who swear by JB Weld. Is possible to use it or some kind of high end epoxy/glue to attach one of those valves from Geno's in place? Jusst a thought , since no one else had gone there. Best of luck.
#24
Thanks for everyone suggestions. My problem is finding a larger drain plug with self taping threads. My plug is 22mm. I have been searching the net and I have found plenty of smaller drain plugs that you can buy oversized with self tapping threads but not in the larger 22mm size. If anyone has any ideas on where to find this that would be great. I called my local Cummins branch but they did not have any. I was thinking someplace that worked on the big trucks would have something like that.
Brazos
Brazos
#25
This just came to mind, as I was installing a faucet outside my garage.....
Go to a plumbing store (Home Depot, whatever) and get a brass fitting that is close to your plug size. Thread it inside and out and use it like a sleeve, like in a engine cylinder.
Just a thought.
Just a thought.
#26
I realize this is from last week, but... go to O'reilly's. Over by the permatex stuff they have some stuff that repairs threads. It is a 2 part mixture. You brush one onto the bolt & the other onto the hole. The part that goes onto the bolt is a releasing agent so that you don't permanently glue your plug in there. I used this on a mower wheel lug nut & it's held up for 2 years now.
#27
Problem Solved. It was not the oild pan as my dealer had told me. The drain plug itself broke. So basically my dodge dealer did not even look at the problem and were trying to hose me for $880 + Tax to replace the oil pan. Though I am pissed at my dealer I am glad it was a quick cheap fix to buy a new drain plug. Thanks for everyone's help and suggestions.
Brazos
Brazos
#29
#30
