Check engine light with only 2800 miles
Old 10-11-2006, 02:57 PM
Dodge This's Avatar
Dodge This
Dodge This is offline
Default RE: Check engine light with only 2800 miles
Has anyone that plugged their truck in have this problem?
Old 10-11-2006, 03:23 PM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
here's the schematic out of the manual...
[IMG]local://upfiles/1508/0962826BF25A4DF0B6AE011B518E9B44.jpg[/IMG]
Old 10-11-2006, 03:34 PM
GOD RAM IT's Avatar
GOD RAM IT
GOD RAM IT is offline
do you have auto start installed on your truck?
I do and my engine light comes on whenever I use it.
Just thought Id throw that out there just in case
Old 10-11-2006, 03:51 PM
chukar's Avatar
chukar
chukar is offline
Codes that came up
P0111 Intake Air Temp Circuit Range/Performance Problem
P0513 No Idea what this code is.
Anyone have an idea of what code P0513 is?
Old 10-11-2006, 04:07 PM
Dodge This's Avatar
Dodge This
I have no auto start. The schematic shows only one sensor that would be the one I found on the drver side batt. Its looks like its pluged in and its not loose. Is that the only sensor? Thanks you guys have been very helpfull?
Old 10-11-2006, 04:26 PM
Drew's Avatar
Drew
Drew is offline
what I could find on the 513 is it is a sentry key misread where the computer saw the wrong transponder code from the key, or the wrong key was used.
Old 10-11-2006, 04:40 PM
chukar's Avatar
chukar
chukar is offline
Well I received three seperate keys. One door only key and two with the remotes built in, I guess those are the Sentry Keys. One of them works fine, but the other one does not. I don't know if the battery in it is dead or what. The buttons do not work and as the manual says the truck starts for 2-3 seconds and then shuts off. I did finally try this key yesterday and discovered this. I should have made sure they both worked when I bought it, but who would have thought that a brand new key would have a dead battery!
Is there a way I can reset these codes myself? We have no Autozone in this part of the world, and would have to pay a dealership or shop to do it since the truck was not purchased in-town either.
Old 10-11-2006, 05:48 PM
Dodge This's Avatar
Dodge This
Does any one know if there is only one batt. sensor. The only one I can find is on the driverside batt.
Old 10-11-2006, 06:52 PM
steve05ram360
the manual only show'd 1 sensor and it did not indicate which side it was on. leme go look some more...
Old 10-11-2006, 06:56 PM
steve05ram360
the bell just went off in my head... I just rememberd that when I did the battery disconnect thing, it set another code, there was a code for a battery disconnect/discharge of some sorts. did you disconnect the battery after re-setting the pcm with the scanner the 1st time?
Quick Reply: Check engine light with only 2800 miles
